Dayton Audio DCS205-4 8" Classic Subwoofer 4 Ohm
Brand:|Model: DCS205-4|Part # 295-200
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses.
List Price$66.99
You Save24%
$51.00
Buy 4+$48.50
Part # 295-200
  • Sturdy stamped steel frame
  • Vented pole piece and bumped back plate
  • Inductance-reducing copper pole piece cap
  • Treated non-pressed paper/Kevlar cone with rubber surround
  • 4-layer VC with polyimide former
  • Great for home and automotive applications
  • Five year warranty
The Dayton Audio Classic Series subwoofers offer solid value at lower price points. No compromises were made in the design, materials, or construction of these rugged 4-ohm powerhouses. The drivers feature a vented pole piece with copper cap, bumped back plate for improved excursion capability, Kevlar reinforced cone with rubber half-roll surround, and a high-temperature 4-layer copper voice coil wound on a polyimide former.
  • Nominal Diameter8"
  • Power Handling (RMS)150 Watts
  • Power Handling (max)300 Watts
  • Impedance4 ohms
  • Frequency Response30 to 200 Hz
  • Sensitivity88.6 dB 2.83V/1m
  • Voice Coil Diameter1.51"
  • Resonant Frequency (Fs)32.3 Hz
  • DC Resistance (Re)3.9 ohms
  • Voice Coil Inductance (Le)1.78 mH
  • Mechanical Q (Qms)6.28
  • Electromagnetic Q (Qes)0.4
  • Total Q (Qts)0.37
  • Compliance Equivalent Volume (Vas)0.95 ft.³
  • Mechanical Compliance of Suspension (Cms)0.42 mm/N
  • BL Product (BL)10.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)57.7g
  • Maximum Linear Excursion (Xmax)8.8 mm
  • Surface Area of Cone (Sd)213.8 cm²
  • Cone MaterialPaper / Kevlar
  • Surround MaterialRubber
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.19"
  • Baffle Cutout Diameter7.09"
  • Depth4.23"
  • Bolt Circle Diameter7.80"
  • # Mounting Holes8
  • Sealed Volume0.19 ft.³
  • Sealed F378 Hz
  • Vented Volume0.48 ft.³
  • Vented F348 Hz
  • BrandDayton Audio
  • ModelDCS205-4
  • Part Number295-200
  • UPC844632080654
    (27 Reviews)
  • Weight6.65 lbs.
View similar products to the Dayton Audio DCS205-4 8" Classic Subwoofer 4 Ohm
