Dayton Audio DC380-8 15" Classic Woofer
Brand:|Model: DC380-8|Part # 295-325
The Dayton Audio Classic Series 15" woofer is excellent as a replacement driver or for new system design and construction. The versatile set of parameters makes it suitable for sealed or vented enclosure designs.
List Price$92.99
You Save23%
$71.66
Buy 4+$68.60
Part # 295-325
  • Treated paper cone provides smooth response and low energy storage
  • Aluminum former, vented pole piece, and porous dustcap for high power handling
  • Large diameter flat spider and healthy Xmax for clean bass
  • Bring those old vintage speakers back to life
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC380-8 15" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. Smooth frequency response and extended bass performance make this driver ideal for use in large format two-way and classic three-way loudspeaker designs. A Qts of 0.35 allows the DC300-8 to work well in both sealed and ported speaker enclosures.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter15"
  • Power Handling (RMS)100 Watts
  • Power Handling (max)200 Watts
  • Impedance8 ohms
  • Frequency Response20 to 1,500 Hz
  • Sensitivity91.8 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)18.8 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)3.09 mH
  • Mechanical Q (Qms)2.87
  • Electromagnetic Q (Qes)0.34
  • Total Q (Qts)0.30
  • Compliance Equivalent Volume (Vas)13.82 ft.³
  • Mechanical Compliance of Suspension (Cms)0.39 mm/N
  • BL Product (BL)20.4 Tm
  • Diaphragm Mass Inc. Airload (Mms)182.9g
  • Maximum Linear Excursion (Xmax)4.35 mm
  • Surface Area of Cone (Sd)834.7 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter15.16"
  • Baffle Cutout Diameter13.74"
  • Depth6.38"
  • Bolt Circle Diameter14.37"
  • # Mounting Holes8
  • Sealed Volume2 ft.³
  • Sealed F353 Hz
  • Vented Volume5.27 ft.³
  • Vented F332 Hz
  • BrandDayton Audio
  • ModelDC380-8
  • Part Number295-325
  • UPC844632000287
  • Product CategoryWoofers
    (44 Reviews)
  • Weight11.5 lbs.
View similar products to the Dayton Audio DC380-8 15" Classic Woofer
