Dayton Audio DC300-8 12" Classic Woofer
Brand:|Model: DC300-8|Part # 295-320
Choose the Dayton Audio DC300-8 Classic Series 12" woofer for use as a great replacement speaker for large format 2-way and 3-way, ported or sealed loudspeakers.
List Price$53.99
You Save23%
$41.41
Buy 4+$39.42
Part # 295-320
  • Works great as a general replacement woofer
  • Excellent price/performance ratio
  • Bring those old vintage speakers back to life
  • Long lasting rubber surround increases the life of the driver
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC300-8 12" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. Smooth frequency response and extended bass performance make this driver ideal for use in large format two-way and classic three-way loudspeaker designs. A Qts of 0.43 allows the DC300-8 to work well in both sealed and ported speaker enclosures.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter12"
  • Power Handling (RMS)80 Watts
  • Power Handling (max)160 Watts
  • Impedance8 ohms
  • Frequency Response25 to 2,500 Hz
  • Sensitivity90.3 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Magnet Weight30 oz.
  • Resonant Frequency (Fs)22.9 Hz
  • DC Resistance (Re)6.8 ohms
  • Voice Coil Inductance (Le)2.93 mH
  • Mechanical Q (Qms)3.21
  • Electromagnetic Q (Qes)0.37
  • Total Q (Qts)0.33
  • Compliance Equivalent Volume (Vas)6.41 ft.³
  • Mechanical Compliance of Suspension (Cms)0.48 mm/N
  • BL Product (BL)16.3 Tm
  • Diaphragm Mass Inc. Airload (Mms)100.7g
  • Maximum Linear Excursion (Xmax)4.3 mm
  • Surface Area of Cone (Sd)498.8 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter12.07"
  • Baffle Cutout Diameter11"
  • Depth5.18"
  • Bolt Circle Diameter11.5"
  • # Mounting Holes8
  • Sealed Volume1.47 ft.³
  • Sealed F352 Hz
  • Vented Volume4.58 ft.³
  • Vented F328 Hz
  • BrandDayton Audio
  • ModelDC300-8
  • Part Number295-320
  • UPC844632000270
  • Product CategoryWoofers
    (82 Reviews)
  • Weight7.8000 lbs.
  • Warranty5 Years
View similar products to the Dayton Audio DC300-8 12" Classic Woofer
