Dayton Audio DC28F-8RD 1-1/8" Silk Replacement Diaphragm
Brand:|Model: DC28F-8RD|Part # 275-072
Replacement Diaphragm for Dayton Audio DC28F Series tweeters
List Price$16.99
You Save27%
$12.45
Buy 4+$11.85
Part # 275-072
  • TypeTweeter Diaphragms
  • BrandDayton Audio
  • ModelDC28F-8RD
  • Part Number275-072
  • UPC844632070730
  • Product CategoryReplacement Diaphragms
    (2 Reviews)
  • Weight0.2 lbs.
View similar products to the Dayton Audio DC28F-8RD 1-1/8" Silk Replacement Diaphragm
in the Replacement Diaphragms product category.
Dayton Audio DC28F-8RD 1-1/8" Silk Replacement Diaphragm is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from good productthis was a replacement for my behringer studio speakers sounds way better than the small titanium diaphragms
Date published: 2011-11-21
Rated 5 out of 5 by from Worked as good as the original.This was a replacement for defective diaphragm. This one was assembled much sturdier than the original one that broke and was easy to install. The sound quality is equal to the original. I will probably order a couple more to store as spares.
Date published: 2011-04-01
  • 2016-02-13T06:45CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_275-072, PRD, sort_mostRecent
what diameter is the voice coil on this?
Asked by: mikemunie
This has a 1-1/8" diameter voice coil.
Date published: 2015-10-21
Could this be used in a custom waveguide? If so, any suggestions? Thanks.
Asked by: Matt_Getz
This is only a replacement diaphragm so it will not work without the magnet structure. You will want to look at the DC28F tweeter for the full version. Dome tweeters will work in waveguides but the waveguides usually require heavy modification in order to work with them.
Date published: 2015-06-02
Dayton Replacement Dome
I have a DAYTON DC28F-8 1-1/8" SILK DOME TWEETER and the diaphragm is damaged. I purchased (from PE) a Dayton Audio DC28F-8RD 1-1/8" Silk Replacement Diaphragm however it does on fit into the original face plate.How do I replace the diaphragm?
Asked by: Splatter
This is the exact replacement for the DC28F tweeter. I an sorry to say that if it does not slide in around the perminant voice coil magnet then it (replacement diaphragm) may have gotten slightly out of round.Occasionally when a diaphram goes bad, and you remove it, some residue from the old one is left in the gap. This will not allow the replacement to slide into place. Check for this and and if you find debris gently remove it being careful not to scratch or mar the surface in any way. This will affect sound production.I often use a Q-tip and solvent just to make sure the gap is clean. If it is out of round, you can gently guide it into place but if it is too severe then it will not work well. This is why they are packaged so well.Good luck.
Answered by: Nitnub
Date published: 2012-03-20
  • 2016-02-13T07:41CST
  • loc_en_US, sid_275-072, PRD, sort_recentQuestionsFirst
