Dayton Audio DC200-8 8" Classic Woofer
Brand:|Model: DC200-8|Part # 295-310
The Dayton Audio DC200-8 Classic Series 8" woofer achieves high levels of performance at a reasonable price. It's perfect as the basis of a custom speaker project, or for repairs and upgrades.
List Price$32.99
You Save23%
$25.27
Buy 4+$24.10
Part # 295-310
  • Great price/performance ratio
  • Treated non-pressed paper cone with rubber surround
  • Vented pole piece for better power handling
  • Clean, balanced sound quality
Dayton Audio's DC200-8 Classic Series 8" woofer offers one of the best price/performance values available anywhere. This DC200-8 8" speaker, and in fact the whole Classic Series, has a non-pressed treated paper cone, ASV voice coil, vented pole piece, rubber surround, coated cloth dust cap, and excellent low frequency performance.
  • Nominal Diameter8"
  • Power Handling (RMS)60 Watts
  • Power Handling (max)120 Watts
  • Impedance8 ohms
  • Frequency Response29 to 3,000 Hz
  • Sensitivity87 dB 2.83V/1m
  • Voice Coil Diameter1.38"
  • Magnet Weight15 oz.
  • Resonant Frequency (Fs)30.3 Hz
  • DC Resistance (Re)6.41 ohms
  • Voice Coil Inductance (Le)2.32 mH
  • Mechanical Q (Qms)3.06
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.42
  • Compliance Equivalent Volume (Vas)1.61 ft.³
  • Mechanical Compliance of Suspension (Cms)0.77 mm/N
  • BL Product (BL)9.5 Tm
  • Diaphragm Mass Inc. Airload (Mms)36.1g
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)211.2 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter8.07"
  • Baffle Cutout Diameter7.2"
  • Depth3.68"
  • # Mounting Holes4
  • Sealed Volume0.46 ft.³
  • Sealed F366 Hz
  • Vented Volume1.36 ft.³
  • Vented F337 Hz
  • BrandDayton Audio
  • ModelDC200-8
  • Part Number295-310
  • UPC844632000256
  • Product CategoryWoofers
    (126 Reviews)
  • Weight3.5 lbs.
View similar products to the Dayton Audio DC200-8 8" Classic Woofer
Dayton Audio DC200-8 8" Classic Woofer is rated 4.4841 out of 5 by 126.
Rated 5 out of 5 by from Well worth the moneyMy brother wanted some speakers built but didn't want to spend much money. I took my Hivi 8" and 6" speakers and my tweeters out of my build and put in this 8" Dayton and a 8" passive radiator to keep cost down. I'll use my Hivi for my next build. I had some old Polk 2 way speakers with the woofers blown. Used the tweeters and the x overs out of them for this build. The sound that these woofers produce is amazing. You not only get deep tight bass but clear crisp midrange. You cant beat the sound quality for the money. As always Parts Express is wonderful to work with.
Date published: 2015-12-31
Rated 4 out of 5 by from Bring the BoomI bought these speakers to drop into a pair of Optimus - 8" 2-Way Bookshelf speaker cabinets. The cabinets are .51 cu. ft. volume & have a 1 1/2" diameter port tube & have them tuned 40Hz. These are some good speakers for booming bass, which is what I like. The paper dust cap had me worried a bit but I was relieved when I seen that They are pretty stiff. Also the rubber surrounds on the speaker are pretty soft, so they should break in pretty quickly. I say ruffly 10 hours of use at normal playing levels & they are all freed up. These really are excellent speakers for the money & you can't go wrong buy some.
Date published: 2015-11-07
Rated 5 out of 5 by from Worked perfectly in my applicationUsed the them on an old set of Advent prodigy towers, sounded better than new
Date published: 2015-10-19
Rated 5 out of 5 by from Nice produc.fast shippingHappy with the product and the shipping only took a few days.
Date published: 2015-10-18
Rated 5 out of 5 by from Gained Exceptional Bass Response!A friend at my work had an old set of AR93Q's he wanted to replace and he said I could have them if I hauled them away. All the original drivers were crapped out and had been poorly re-surrounded. I mean the glue jobs were a mess. I didn't care about restoring original parts, I just wanted good sound. First I replaced the tweeters and mid-bass units with Parts Express Part # 292-554 and Part # 264-330 respectively. I knew I had done well when the new drivers sounded exactly like the ones I had replaced. I wasn't going so much for an improvement in sound as I was the same sound, but newer components. The side firing woofers were next on the list, and I needed 4, so I chose these babies, and WOW!!! The difference in bass from the old woofers to these new Dayton Audio's was phenomenal. I was wondering if I had accidentally bumped my subwoofer's volume control after I had finished installing these and gave a listen test. It seemed like I gained another octave deeper in response, and this was with no extensive break-in period, like some woofers need. I can only expect better performance as these finally DO get broken in. Here you see my speakers in their semi-finished state. I have installed metal grills over the side firing units and plan on making grills to cover the front firing speakers. I was not fond of AR's original "Pillow Case" speaker grills, so I trashed those immediately. Once I complete these I will post a review with finished pictures of the grills installed. These woofers are awesome, glad I got them. Thanks again Parts Express.
Date published: 2015-05-25
Rated 5 out of 5 by from Great ProductA friend referee me to your company, and I am extremely Happy they did. Great products at Great prices!!
Date published: 2015-04-26
  • 2016-02-13T06:44CST
  • co_hasreviews, tv_0, tr_126
  • loc_en_US, sid_295-310, PRD, sort_mostRecent
do the holes match-up with those on bose 601 series III?
Asked by: drJayman
I am sorry, we do not have the bolt circle specification available for the Bose. In general aftermarket speakers do not match up exactly and new holes are required to mount though.
Answered by: Chrisf
Date published: 2016-02-02
Would a 1.36 cubic foot box with a 1.5" slotted port work with these woofers ?
Asked by: 88fritz
The airspace is fine, its best to tune this to 32 Hz. The easiest would be a round 2 inch port that is 4 inches long but you can also get there with a rectangular port if you wish.
Answered by: Chrisf
Date published: 2016-02-04
I have an old Sherwood SP-250 passive bass module that was used in conjunction with left/right satellites.  I am looking to repurpose the bass module (woofer is shot) to supplement the low end of my center channel/speaker.  What's your advice?
Asked by: Ike0223
I would start by checking the physical mounting. Make sure that the hole in the cabinet and frame diameter are compatible with your box. Once you verify that, let us know your cabinets internal dimensions and any information you have on the crossover. Just send the information to tech@parts Express and we will be happy to see how this driver will perform in that application.
Answered by: Chrisf
Date published: 2016-01-27
What would be the price of 4 woofers plus postage to Australia? I want to build an mtm like the angel fire mtm. I read you need a better tweeter for midrange, what do you recommend?  Is a 4.4 cubic box over kill. Is 25 or near that possible? Thankyou
Asked by: Jaroldo84
Answered by: MattW
Date published: 2015-11-17
What size port using this in a .77 cubic foot enclosure?
Asked by: yamvmax
A 2" diameter, 10" long port will tune this to 30 Hz.
Date published: 2015-11-11
Can this be used as a downfiring woofer?
Asked by: yamvmax
Yes.
  • 2016-02-13T07:38CST
  • co_hasquestionsanswers, tq_55
  • loc_en_US, sid_295-310, PRD, sort_recentQuestionsFirst
