Dayton Audio DC160S-4 6-1/2" Classic Shielded Woofer 4 Ohm
Brand:|Model: DC160S-4|Part # 295-308
Choose the Dayton Audio DC160S-4 Classic Series 6-1/2" shielded woofer for use as a great replacement bookshelf speaker, midbass in 3-way designs, or even as a small subwoofer.
List Price$34.99
You Save24%
Buy 4+$25.24
Part # 295-308
  • Treated paper cone provides smooth response and low energy storage
  • Aluminum former, vented pole piece, and porous dustcap for high power handling
  • Large diameter flat spider and good Xmax for clean bass
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC160S-4 6-1/2" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even be use the DC160S-4 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate. The 4 ohm impedance of the DC160S-4 makes it perfect for use in MTMs and center channel speakers.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance4 ohms
  • Frequency Response33 to 4,000 Hz
  • Sensitivity88.5 dB 2.83V/1m
  • Voice Coil Diameter1.38"
  • Resonant Frequency (Fs)30.9 Hz
  • DC Resistance (Re)3.5 ohms
  • Voice Coil Inductance (Le)0.89 mH
  • Mechanical Q (Qms)2.61
  • Electromagnetic Q (Qes)0.34
  • Total Q (Qts)0.30
  • Compliance Equivalent Volume (Vas)0.82 ft.³
  • Mechanical Compliance of Suspension (Cms)0.88 mm/N
  • BL Product (BL)7.68 Tm
  • Diaphragm Mass Inc. Airload (Mms)30g
  • Maximum Linear Excursion (Xmax)3.4 mm
  • Surface Area of Cone (Sd)136.8 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.69"
  • Depth3.74"
  • Bolt Circle Diameter6.16"
  • # Mounting Holes4
  • Sealed Volume0.15 ft.³
  • Sealed F390 Hz
  • Vented Volume0.41 ft.³
  • Vented F352 Hz
  • BrandDayton Audio
  • ModelDC160S-4
  • Part Number295-308
  • UPC844632000973
  • Product CategoryWoofers
    (17 Reviews)
  • Weight5 lbs.
View similar products to the Dayton Audio DC160S-4 6-1/2" Classic Shielded Woofer 4 Ohm
