Dayton Audio DC160-8 6-1/2" Classic Woofer
Brand:|Model: DC160-8|Part # 295-305
Choose the Dayton Audio DC160-8 Classic Series 6-1/2" woofer for use as a great replacement bookshelf speaker, midbass in 3-way designs, or even as a small subwoofer.
List Price$27.99
You Save22%
Buy 4+$20.78
Part # 295-305
  • Great bang-for-the-buck driver can be used as a woofer, midbass, or even as a small subwoofer!
  • Smooth frequency response up to 2 kHz and great bass response
  • Rubber surround, aluminum voice coil, and extended bump plate
  • Low 34 Hz free-air resonance
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC160-8 6-1/2" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even be use the DC160-8 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil and vented pole piece combine to increase power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter6-1/2"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response30 to 4,000 Hz
  • Sensitivity86.1 dB 2.83V/1m
  • Voice Coil Diameter1.38"
  • Magnet Weight15 oz.
  • Resonant Frequency (Fs)35.7 Hz
  • DC Resistance (Re)6.6 ohms
  • Voice Coil Inductance (Le)2.26 mH
  • Mechanical Q (Qms)3.46
  • Electromagnetic Q (Qes)0.38
  • Total Q (Qts)0.34
  • Compliance Equivalent Volume (Vas)0.63 ft.³
  • Mechanical Compliance of Suspension (Cms)0.68 mm/N
  • BL Product (BL)10.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)29.3g
  • Maximum Linear Excursion (Xmax)3.15 mm
  • Surface Area of Cone (Sd)134.8 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.5"
  • Baffle Cutout Diameter5.69"
  • Depth3.24"
  • Bolt Circle Diameter6.16"
  • # Mounting Holes4
  • Sealed Volume0.14 ft.³
  • Sealed F389 Hz
  • Vented Volume0.34 ft.³
  • Vented F354 Hz
  • BrandDayton Audio
  • ModelDC160-8
  • Part Number295-305
  • UPC844632000232
  • Product CategoryWoofers
    (105 Reviews)
  • Weight3.3 lbs.
View similar products to the Dayton Audio DC160-8 6-1/2" Classic Woofer
