Dayton Audio DC130BS-8 5-1/4" Classic Shielded Woofer
Brand:|Model: DC130BS-8|Part # 295-301
Choose the Dayton Audio DC130BS-8 Classic Series 5-1/4" shielded woofer for use as a great replacement bookshelf speaker, midbass in 3-way designs, or even as a small subwoofer.
List Price$25.99
You Save24%
$19.87
Buy 4+$18.15
Part # 295-301
  • Great bang-for-the-buck driver can be used as a woofer, midbass, or even as a small subwoofer!
  • Smooth frequency response up to 2 kHz and great bass response
  • Rubber surround, aluminum voice coil, and extended bump plate
  • Shielded design increases performance and allows it to be used near tube TVs
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC130BS-8 5-1/4" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even be use the DC130BS-8 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil increases power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response55 to 4,000 Hz
  • Sensitivity88.9 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Magnet Weight10 oz.
  • Resonant Frequency (Fs)50.5 Hz
  • DC Resistance (Re)5.8 ohms
  • Voice Coil Inductance (Le)0.82 mH
  • Mechanical Q (Qms)1.82
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.39
  • Compliance Equivalent Volume (Vas)0.31 ft.³
  • Mechanical Compliance of Suspension (Cms)1.13 mm/N
  • BL Product (BL)5.71 Tm
  • Diaphragm Mass Inc. Airload (Mms)8.8g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)91.6 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.71"
  • Baffle Cutout Diameter4.72"
  • Depth3.05"
  • Bolt Circle Diameter5.24"
  • # Mounting Holes4
  • Sealed Volume0.11 ft.³
  • Sealed F3116 Hz
  • Vented Volume0.35 ft.³
  • Vented F361 Hz
  • BrandDayton Audio
  • ModelDC130BS-8
  • Part Number295-301
  • UPC844632000225
  • Product CategoryWoofers
    (6 Reviews)
  • Weight2.6 lbs.
View similar products to the Dayton Audio DC130BS-8 5-1/4" Classic Shielded Woofer
Dayton Audio DC130BS-8 5-1/4" Classic Shielded Woofer is rated 4.5 out of 5 by 6.
Rated 5 out of 5 by from An Excellent Woofer for the moneyI got this woofer to replace broken woofers in a pair of broken bookshelf speakers. I they did not fit but with enclosure modification, I made them fit.The Performance is really good on these woofers. they sound nice and handle bass well. They sound really nice for the money. I do recommend these woofers for any speaker builders looking for a nice strong woofer that is cheap. The build quality of these woofers are also nice.The Only downside I see to the product is that the speaker lead tabs are the same size, however it was not an issue for me.
Date published: 2011-08-19
Rated 4 out of 5 by from good driverCant beat it all around for the money!
Date published: 2011-01-31
Rated 4 out of 5 by from nice wooferAAA++++
Date published: 2009-06-19
Rated 5 out of 5 by from Great ValueI used these woofers to replace the stock 5.5 X 7.5 6-ohm woofers in a Mustang s Mach 460 sound system. I have another Mustang with the same sound system for comparison. They are installed in the doors. They are wired in parallel to an 85-watt amp. The low-pass signal to the amp starts to ramp down above around 1000 hz. I fabricated adapters from .5 inch MDF. The result is fantastic in comparison to the stock woofers. Bass is tight and clean. I am very satisfied with these woofers, and I will be upgrading the other Mustang s sound system with them. One of the speakers had a loose voice coil that was slapping at moderate volume and up. Parts Express promptly shipped a replacement. Great customer service.
Date published: 2009-04-17
Rated 5 out of 5 by from Good Vibrations!I bought these drivers to replace the woofers in my Optimus PRO-LX5 II speakers. WOW, what a great full sound. Coupled with my Sub woofer, the house shakes like never before. Very pleased with my purchase.
Date published: 2008-01-12
Rated 4 out of 5 by from Pretty Good Woofer For A Center Speaker DesignBought A Pair Of These For A Center Speaker Project, To Go With My Classic 6 1/2" MTM's! Kept The Crossover At 2500Hz, They Produce Good Midbass And Blend Well With My Main Speakers.. These Woofers Would No Doupt Make A Good Main Speaker Project!
Date published: 2007-05-29
  • 2016-05-04T06:33CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_295-301, PRD, sort_mostRecent
the complete "depth" is really 3 inches,,? top to bottom,,,, need it for bose 301 cabinet
Asked by: stve
The overall depth of this driver is 3.04 inches from the top to bottom. When mounted from the front, it is 2.80 inches.
Answered by: Chrisf
Date published: 2014-10-01
Paired this woofer with a DC28FS-8 tweeter. Pioneer SX-780 amp 45 watts RMS I can only go just past 50% before the woofers start having issues.  Is the amp putting out more watts than rated or should I use a diff woofer?
Asked by: Subtrauma
Half way on a volume knob for most amplifiers is reaching full output power.These woofers will thermally handle 45 watts as long as the excursion is under control. Most small woofers will reach their mechanical limits before they reach their thermal limits and that is probably the case here.
Date published: 2014-05-20
? does this driver compare to the truncated version
how does this driver compare to the truncated, very difficult to flush mount, DC130AS-8? could this driver, the DC130BS-8, be substituted for the truncated version without X-over mods?same question regarding the non-magnetically shielded DC130B-8?if there are differences, between either/both of the "round" drivers, what modifications would be required to a X-over designed for the truncated DC130AS-8 like the one X-over used in the Wayne's DIY Dayton HT speakers?
Asked by: Axel Chris
These are interchangable, the only difference being the frame shape.
Date published: 2013-06-17
Direct drop in replacement for Optimus Pro LX5?
Asked by: EnderWiggin
Unfortunately we do not offer a direct replacement for the LX5 woofers. We can repair the originals however, please visit the link below for details.http://www.parts-express.com/speakerrepaircenter/index.cfm
Date published: 2013-05-20
box volume for four of these in a two way project for five speakers in a home theater set up and if ported please add port and speaker displacement.
Asked by: frankr
Recommended box size is 1.48 total cubic feet after displacement, so build it to 1.52 total. Vent size is 3" in diameter and 2" long. This will tune the box to 51 Hz.
Date published: 2013-02-12
Magnet/basket volume?
What is the overall volume of this speaker's basket & magnet?
Asked by: EnigmaV8
The displacement of this woofer is 0.0136 cubic feet.
Date published: 2012-12-12
  • 2016-05-04T07:08CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_295-301, PRD, sort_recentQuestionsFirst
