Dayton Audio DC130B-8 5-1/4" Classic Woofer Speaker
Brand:|Model: DC130B-8|Part # 295-304
Dayton Audio's DC130B-8 5-1/4" Classic Series woofer is perfect for compact 2-way designs as well as use in multiples or transmission lines.
List Price$24.99
You Save22%
$19.50
Buy 4+$17.20
Part # 295-304
  • Sturdy, easy-to-countersink round steel frame
  • Coated paper cone provides smooth response and reduced cone breakup
  • Aluminum voice coil former for high power handling
  • Large diameter flat spider and good Xmax for clean bass
  • Suitable for sealed or vented enclosures
One of the main design goals at Dayton Audio is to create loudspeakers that can achieve high levels of performance at reasonable prices. The Dayton Audio DC130B-8 5-1/4" woofer is a great example of this approach. It features a non-pressed treated paper cone, rubber half-roll surround, ASV voice coil, coated cloth dust cap, and excellent low frequency response.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance8 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity89.1 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)52.5 Hz
  • DC Resistance (Re)5.7 ohms
  • Voice Coil Inductance (Le)0.77 mH
  • Mechanical Q (Qms)1.85
  • Electromagnetic Q (Qes)0.48
  • Total Q (Qts)0.38
  • Compliance Equivalent Volume (Vas)0.43 ft.³
  • Mechanical Compliance of Suspension (Cms)1.01 mm/N
  • BL Product (BL)5.94 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.1g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)91.6 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.71"
  • Baffle Cutout Diameter4.72"
  • Depth2.67"
  • Bolt Circle Diameter5.24"
  • # Mounting Holes4
  • Sealed Volume0.14 ft.³
  • Sealed F3107 Hz
  • Vented Volume0.32 ft.³
  • Vented F360 Hz
  • BrandDayton Audio
  • ModelDC130B-8
  • Part Number295-304
  • UPC844632093975
  • Product CategoryWoofers
    (3 Reviews)
  • Weight2.05 lbs.
View similar products to the Dayton Audio DC130B-8 5-1/4" Classic Woofer Speaker
