Dayton Audio DC130B-4 5-1/4" Classic Woofer Speaker
Brand:|Model: DC130B-4|Part # 295-307
The Dayton Audio DC130B-4 5-1/4" woofer is a 4 ohm, round frame version of the popular Classic Series DC130 drivers.
List Price$25.99
You Save23%
$19.90
Buy 4+$18.98
Part # 295-307
  • Sturdy, easy-to-countersink round steel frame
  • 4 ohm impedance offers alternative load possibilities
  • Coated paper cone provides smooth response and reduced cone breakup
  • Aluminum VC former and vented pole piece for high power handling
  • Large diameter flat spider and good Xmax for clean bass
  • Suitable for sealed or vented enclosures
One of the main design goals at Dayton Audio is to create loudspeakers that can achieve high levels of performance at reasonable prices. The Dayton Audio DC130B-4 5-1/4" woofer is a great example of this approach. It features a non-pressed treated paper cone, rubber half-roll surround, ASV voice coil, vented pole piece, coated cloth dust cap, and excellent low frequency response.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)40 Watts
  • Power Handling (max)80 Watts
  • Impedance4 ohms
  • Frequency Response50 to 5,000 Hz
  • Sensitivity92.1 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Magnet Weight11 oz.
  • Resonant Frequency (Fs)50.5 Hz
  • DC Resistance (Re)3.2 ohms
  • Voice Coil Inductance (Le)0.5 mH
  • Mechanical Q (Qms)2.52
  • Electromagnetic Q (Qes)0.41
  • Total Q (Qts)0.35
  • Compliance Equivalent Volume (Vas)0.43 ft.³
  • Mechanical Compliance of Suspension (Cms)1 mm/N
  • BL Product (BL)4.89 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.4g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)91.6 cm²
  • Cone MaterialCoated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.71"
  • Baffle Cutout Diameter4.72"
  • Depth2.67"
  • Bolt Circle Diameter5.24"
  • # Mounting Holes4
  • Sealed Volume0.1 ft.³
  • Sealed F3120 Hz
  • Vented Volume0.22 ft.³
  • Vented F372 Hz
  • BrandDayton Audio
  • ModelDC130B-4
  • Part Number295-307
  • UPC844632093982
  • Product CategoryWoofers
    (5 Reviews)
  • Weight2.05 lbs.
View similar products to the Dayton Audio DC130B-4 5-1/4" Classic Woofer Speaker
