Dayton Audio DC130AS-8 5-1/4" Classic Shielded Woofer
Brand:|Model: DC130AS-8|Part # 295-300
Choose the Dayton Audio DC130AS-8 Classic Series 5-1/4" woofer for use as a great replacement bookshelf speaker, midrange in 3-way designs, or even as a small subwoofer. The shielded design allows for use near tube TVs and focuses the magnetic flux in the gap for high sensitivity.
List Price$25.99
You Save24%
$19.87
Buy 4+$18.15
Part # 295-300
  • Great bang-for-the-buck driver can be used as a woofer, midbass, or even as a small subwoofer!
  • Smooth frequency response up to 2 kHz and great bass response
  • Rubber surround, aluminum voice coil, and extended bump plate
  • Shielded design increases performance and allows it to be used near tube TVs
  • 4 ohm impedance for series pair use in MTMs and center channel speakers
Dayton Audio Classic Series woofers are excellent for use as replacement speakers or for new loudspeaker system design and construction. The DC130AS-8 shielded 5-1/4" woofer has developed quite a reputation for having the best bang-for-the-buck performance and value available anywhere. You can even be use the DC130AS-8 as a small subwoofer! The excellent low frequency performance will amaze you.
A non-pressed treated paper cone allows for smooth frequency response, while the high temperature aluminum voice coil increases power handling without compression. Longevity is ensured with the use of a rubber surround, treated cloth dust cap, and an extended bump plate.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response55 to 4,000 Hz
  • Sensitivity88.5 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Magnet Weight10 oz.
  • Resonant Frequency (Fs)57.2 Hz
  • DC Resistance (Re)5.6 ohms
  • Voice Coil Inductance (Le)0.84 mH
  • Mechanical Q (Qms)2.01
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.45
  • Compliance Equivalent Volume (Vas)0.34 ft.³
  • Mechanical Compliance of Suspension (Cms)0.8 mm/N
  • BL Product (BL)5.83 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.7g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)91.6 cm²
  • Cone MaterialTreated Paper
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.28"
  • Baffle Cutout Diameter4.72"
  • Depth3.09"
  • # Mounting Holes4
  • Sealed Volume0.19 ft.³
  • Sealed F395 Hz
  • Vented Volume0.6 ft.³
  • Vented F347 Hz
  • BrandDayton Audio
  • ModelDC130AS-8
  • Part Number295-300
  • UPC844632000218
  • Product CategoryWoofers
    (29 Reviews)
  • Weight2.5 lbs.
View similar products to the Dayton Audio DC130AS-8 5-1/4" Classic Shielded Woofer
