Dayton Audio DAEXEXT Weatherproof Extreme Exciter 25mm
Brand:|Model: DAEXEXT|Part # 300-376
Outdoor applications are no problem for this hermetically sealed exciter using NXT licensed technology which can be attached to surfaces outdoors to create speakers out of everyday items.
  • Designed for extreme / outdoor environments where normal speakers cannot go
  • Can be used in outdoor environments e.g. in a garage, patio, boating, etc.
  • 3M adhesive disc for secure and fast placement
  • Exciter is sealed in an IP67 rated watertight enclosure
  • NXT Technology ensures good sound quality
The Dayton Audio Extreme Exciter that uses NXT licensed technology is designed to work in "extreme" environments where normal loudspeakers cannot operate. Outdoor applications are no problem for this hermetically sealed (watertight) exciter which can be attached to surfaces outdoors to create speakers out of everyday items. Garage doors, boat cabin structures, garden furniture, etc. can all be made to vibrate using this exciter and thus generate sound. A high performance 3M adhesive disc allows the exciter to be attached to a wide range of materials without any mechanical support required. The exciter has been tested to IP67 which means it is 100% dust-tight and has been immersed in water to a depth of 1m for 1 hour without any liquid entering the exciter chamber. The exciter is supplied with a 9ft. long integrated cable for connection to the source amplifier. One exciter per package.
Specifications:• Power handling: 5 watts RMS/10 watts max • VCdia: 1" • Le: 1 mH • Impedance: 8 ohms • Re: 7.98 ohms • Frequency range: 35-10,000 Hz • Fs: 39 Hz • SPL: 85 dB 1W/1m • Vas: 0 cu. ft. • Dimensions: Overall diameter: 3.43", Depth: 0.71 ".
  • Impedance8 ohms
  • Power Handling (RMS)5 Watts
  • BrandDayton Audio
  • ModelDAEXEXT
  • Part Number300-376
  • UPC844632083563
  • Product CategoryExciters & Tactile Transducers
    (2 Reviews)
  • Weight0.51 lbs.
View similar products to the Dayton Audio DAEXEXT Weatherproof Extreme Exciter 25mm
in the Exciters & Tactile Transducers product category.
