Dayton Audio DAEX58FP Flat Pack 58mm Exciter 25W 8 Ohm
Brand:|Model: DAEX58FP|Part # 295-210
Dayton Audio's DAEX58FP Flat Pack exciter is the perfect choice to turn virtually any solid object into a speaker by vibrating it at speeds of up to 20,000 cycles per second. The DAEX58FP allows for the placement of sound where depth and space is limited.
List Price$19.99
You Save26%
Buy 5+$12.80
Part # 295-210
  • Super small size with low profile height
  • 8 ohm impedance for use in almost any amplifier
  • Includes mounting plate
  • Adds sound to any surface
Ideal for commercial or residential sound applications, the Dayton Audio DAEX58FP Flat Pack exciter easily mounts to most any surface using adhesives (3M tape or gel glue recommended) or screw mounted. A 2-1/4" square plate can be attached to virtually any flat surface to produce amazing sound, creating a speaker from most any surface area.
Surface materials include: cardboard, glass, wood, steel, sheet rock, and more. The 58 mm exciter is heavily used in the automotive, industrial, point-of-sale, retail display, marine, aeronautical industry, digital signage, and art field, along with many other applications where space and depth limitations are a concern.
The flat surface of this transducer can be glued, screwed or double face taped to a wide variety of surfaces to suit almost endless needs. Surfaces include metal cabinets, glass panes, picture frames, wood tiles, under table surfaces, inside display cabinets, cardboard signs, sheet metal and much more.
Typical Applications:
• Retail display cases and store fronts
• Public exhibits
• Self service counters
• Digital signage
• Power handling: 25 watts RMS/40 watts max
• Impedance: 8Ω
• Voice coil diameter: 1.28"
• Dimensions: Overall: 2.28" x 2.28" square, Depth: 0.79"
• Mounting pattern: 2" x 2"
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Dayton Audio's Understanding and Using Dayton Audio Exciters White Paper.
  • Impedance8 ohms
  • Power Handling (RMS)25 Watts
  • BrandDayton Audio
  • ModelDAEX58FP
  • Part Number295-210
  • UPC848791000492
  • Product CategoryExciters & Tactile Transducers
    (6 Reviews)
  • Weight0.3 lbs.
View similar products to the Dayton Audio DAEX58FP Flat Pack 58mm Exciter 25W 8 Ohm
in the Exciters & Tactile Transducers product category.
