295-234_ALT_0
295-234_ALT_1
295-234_ALT_2
295-234_ALT_3
Dayton Audio DAEX32UT-4 Ultra Tripod 32mm 40W 4 Ohm
Brand:| Model: DAEX32UT-4
Turn large, rigid surfaces into speakers with the Dayton Audio DAEX32UT-4. Three screw-down attachment points combine with the pre-attached 3M adhesive for maximum energy transfer, even on moving objects!
  • Heavy-duty design with a 32 mm voice coil for a high 40 watt RMS power handling
  • Three screw-down attachment points for mounting to moving objects
  • Rare-earth neodymium motor and a proprietary two-layer voice coil
  • 4-ohm impedance for use with small, Class D amplifiers
295-234
Weight: 0.3500 lbs.
OUT OF STOCK
Due In: 9/30/2014
List Price$22.99
You Save23%
$17.50
Buy 10-up$15.56
Part # 295-234
Dayton Audio's DAEX32UT-4 Ultra Tripod exciter is built to turn large, thick, rigid surfaces into speakers. The 32 mm voice coil makes it perfect for large glass panes, furniture, and surfaces that would normally resist the effects of an exciter.
A neodymium magnet is employed to create maximum magnetic flux around the proprietary voice coil for increased sensitivity when compared to similar sized exciters. In turn, this reduces power requirements and makes it possible to use very small Class D audio amplifiers, without sacrificing total output.
To ensure maximum acoustic energy transfer between the transducer and the surface to which it is attached, 3M VHB (Very High Bond) adhesive is pre-applied to the main body... just peel and stick! Three screw-down attachment points offer maximum power transfer, even when attached upside-down or on moving objects. Two male spade quick-disconnect terminals are built onto the main body for quick electrical connection.
Note: An exciter's frequency response and sensitivity are completely dependent on the exciter's designated surface. Thinner, smaller materials will tend to be louder and create a mid/tweeter response. Thicker, larger materials (with multiple exciters) will be slightly quieter but result in a more full-range sound.
Specifications: • Power handling: 40 watts RMS • VCdia: 32 mm • Nominal impedance: 4 ohms • Re: 3.5 ohms • Le: 0.51 mH • Fs (uncoupled): 1,117 Hz • Dimensions: 3.35" (85 mm) overall diameter x 0.75" (19 mm) total height • Adhesive dimensions: 1.64" (41.7 mm) outside diameter, 0.86" (21.7 mm) inside diameter • Weight: 137.4 grams.
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Dayton Audio's Undertanding Exciters White Paper.
  • ApplicationFull-Range Exciter
  • Impedance4 ohms
  • Power Handling (RMS)40 Watts
  • BrandDayton Audio
  • ModelDAEX32UT-4
  • Part Number295-234
  • UPC848791001055
  • Product CategoryTactile Transducers, Exciters & Bass Shakers
    (3 Reviews)
  • Weight0.3500 lbs.
View similar products to the Dayton Audio DAEX32UT-4 Ultra Tripod 32mm 40W 4 Ohm
in the Tactile Transducers, Exciters & Bass Shakers product category.
Dayton Audio DAEX32UT-4 Ultra Tripod 32mm 40W 4 Ohm is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from excellent driver for the money!I bought two of these after destroying 2 of the similar round model. The difference between the two models is that the 3 eared version has the speaker terminals moving with the voice coil, while the round one has the terminals on the magnet side. Both of mine failed from over exercising those little wires. Heat is the only challenge with the three eared version.
Date published: 2014-07-21
Rated 5 out of 5 by from Attention Gamers!While these gems won't shake your whole living room floor the way a ButtKicker LFE (300-9400) can, they are relatively inexpensive and can certainly provide some kick to your desk chair. They don't require a separate amplifier either. You can run them from the subwoofer channel.These will mount to the plastic back or seat of most desk chairs but if the plastic is textured, i recommend you drill three small holes and add some self-tapping screws through the built-in mounting bracket.These will also mount (without screws) to those resin chairs you have on your deck but be sure to select a clean dry surface.
Date published: 2014-07-19
Rated 5 out of 5 by from Incredible soundI just pick up my Dayton Audio DAEX32UT-4, and I must say it sounds better than I expected! Excellent sound right across the frequency spectrum. After messing around a few materials in the house, I found that it plays well with foam board and that white foam thingy that they use to protect appliances.
Date published: 2014-05-31
The catalog page shows three mounting tabs. The associated PDF data sheet does not. Which is correct?
Asked by: ddf1
There are two versions of this exciter, one has tabs and the other does not. The same spec sheet is used for both. This exciter does have three mounting tabs as pictured.
Date published: 2014-09-02
Customer projects that include: Dayton Audio DAEX32UT-4 Ultra Tripod 32mm 40W 4 Ohm
