Dayton Audio DAEX25W-8 Waterproof 25mm Exciter 10W 8 Ohm
Brand:|Model: DAEX25W-8|Part # 295-232
Inclement conditions are no problem for this hermetically sealed exciter, which can be attached to surfaces outdoors to create speakers out of everyday items.
List Price$24.99
Regular Price$19.88
You Save22%
Sale Price
$15.60
Part # 295-232
  • Designed for extreme outdoor environments where normal speakers cannot go
  • 3M™ VHB™ adhesive disc for secure, fast placement
  • IP67 rated watertight enclosure
  • Includes a 68" wiring harness
The Dayton Audio's DAEX25W-8 exciter is designed to work in extreme environments where normal loudspeakers cannot operate. Outdoor applications are no problem for this hermetically sealed (watertight) exciter which can be attached to surfaces outdoors to create speakers out of everyday items. Garage door, boat cabin structures, garden furniture, etc. can all be made to vibrate using this exciter and thus generate sound.
A high performance 3M VHB (Very High Bond) adhesive disc allows the DAEX25W-8 to be attached to a wide range of materials without any mechanical support required, and an IP67 rating means it is 100% dust-tight and has been immersed in water to a depth of 1 meter for 1 hour without any liquid entering the exciter chamber. A 68" long integrated cable is included for connection to an amplifier.
Specifications: • Power handling: 10 watts RMS • VCdia: 25 mm • Nominal impedance: 8 ohms • Re: 7.6 ohms • Le: 0.58 mH • Fs (uncoupled): 1,276 Hz • Dimensions: 2.76" (70.2 mm) overall diameter x 0.83" (21 mm) total height • Adhesive dimensions: 1.81" (46 mm) diameter • Weight: 83.9 grams.
To learn more about Dayton Audio Exciters, and for help on which Exciter is right for you, check out Dayton Audio's Understanding and Using Dayton Audio Exciters White Paper.
  • Impedance8 ohms
  • Power Handling (RMS)10 Watts
  • BrandDayton Audio
  • ModelDAEX25W-8
  • Part Number295-232
  • UPC848791001048
  • Product CategoryExciters & Tactile Transducers
    (1 Reviews)
  • Weight0.3000 lbs.
