SALE
300-330_ALT_0
300-330_ALT_1
300-330_ALT_2
300-330_ALT_3
Dayton Audio DA30 2 x 15W Class D Bridgeable Mini Amplifier
Brand:|Model: DA30|Part # 300-330
Choose the Dayton Audio DA30 amplifier for your fixed audio application. Its small chassis fits away neatly for security, while the big sound fills classrooms and conference rooms.
List Price$119.99
Regular Price$78.00
You Save13%
Sale Price
$68.00
Part # 300-330
  • 2 x 15W power output into 4 ohms or 1 x 30W bridged output into 8 ohms
  • Clear, articulate hi-fi sound quality, but built for the tough requirements of commercial duty
  • Cool-running Class D circuitry delivers high output while reducing AC line current demands
  • Ideal for classrooms, boardrooms, or bedrooms
  • Recessed, tamper-resistant tone controls provide simple sound shaping
  • Compact size makes it easy for this amp to fit almost anywhere
  • Add a Bluetooth receiver (sold separately) for even greater control flexibility!
Dayton Audio's DA30 is the ideal amplifier for commercial audio installations such as classrooms or offices, where a small, low wattage power amp is required. This palm-sized Class D amplifier sits inconspicuously on a desktop, and can also be installed on walls or under cabinets by using the included brackets. Perfect for powering ancillary zones in large setups, or mounted on or near a video projector!
The DA30 delivers 15 watts per channel in stereo mode and 30 watts when bridged mono. Two stereo audio inputs increase versatility: dual RCA or a single 3.5 mm TRS jack. Separate treble and bass controls allow the sound to be tailored to the room. The DA30's auto-on feature increases energy efficiency. An all-metal chassis and the selection of high-spec internal components ensure reliable operation and a long service life.
Specifications: • Power output: 2 x 15W RMS into 4 ohms, 1 x 30W into 8 ohms • Efficiency: 92% • Total harmonic distortion: 0.015% 20-20,000 Hz • Bass/treble turnover: 100 Hz/10,000 Hz • Input impedance: 100k ohms • Auto-on sensitivity: <0.8V • Stand-by current consumption: 0.6 mA • Power supply: 24 VDC, 2000 mA • Dimensions (H x W x D): 1-5/8" x 4-7/16" x 5-1/2".
  • BrandDayton Audio
  • ModelDA30
  • Part Number300-330
  • UPC848791000317
  • Product CategoryHome Audio Amplifiers
    (18 Reviews)
  • Weight1.9 lbs.
View similar products to the Dayton Audio DA30 2 x 15W Class D Bridgeable Mini Amplifier
in the Home Audio Amplifiers product category.
Dayton Audio DA30 2 x 15W Class D Bridgeable Mini Amplifier is rated 4.5 out of 5 by 18.
Rated 5 out of 5 by from Tiny reliable powerI bought this to use as a universal amplifier for my work to power 4 8 ohm realistic minimus speakers wired two into 4 ohm load per channel. All of which have metal cases and grills. It is powerful and does the job better then all the other setups we have tried. This tiny amp has the side mount tabs that allow you to top mount or under mount this amp. I have a bluetooth 4.0 aptx module for the input. This has allowed all of the employees to play their music without leaving their phones in harms way. I like the controls being recessed so people do not tamper with the tone and balance settings so we don't get blown speakers from them "Tuning" the system. This is the best mini amplifier I have bought.For a backround music system this rocks. I have a subwoofer that has a wall mount (designed for commercial use) that I may get another da30 in bridged mono to fill in the lower tone.
Date published: 2015-12-11
Rated 3 out of 5 by from Good sound with a few hiccups.TL;DR summary: high quality and powerful, auto on-off is annoying, gain is way too high.I was worried this 15 watt per channel amp wouldn't be enough, because I was previously using an 100 watt per channel amp but to my surprise this amp has plenty of power. HOWEVER, it's gain is set waaaaaaaaaaaaaaay too high. I have to have the volume a 1/4th otherwise there's a channel imbalance, and using out of my Fiio X3's line-out and my Schiit Modi I have to set my computer volume at around 20/100 otherwise this amp isn't useable. The sound quality is great and it runs cool even at loud volumes for extended times, I just can't get it to be quiet easily and I find that annoying. I also find the auto-on and off quite annoying seeing as how I use this amp with a computer, having to wait and hear the click every time I turn on a video or play a song from silence is mildly annoying. For some uses this amp is exceptional, for mine it's not so great but it was the cheapest and highest quality amp I saw on parts-express so I didn't have much choice.
Date published: 2015-11-27
Rated 5 out of 5 by from Best Small AmpI wanted to have a nice portable audio system but portable speakers have poor sound quality or cost hundreds of dollars. Even the Bose Soundlink mini has big flaws in its audio. Also if they break you have to pay hundreds more to replace the whole thing. I wanted to instead use a single bookshelf speaker with an amplifier and Bluetooth receiver.GOOD: This amplifier is one of few that can be bridged which is great for a mono setup. Its very powerful for its size and does not distort. Also the tone controls work great. The amp is very small and light which is good for portability. It comes with mounting brackets.BAD: It has a goofy wire plug that requires the wire to be screwed into with a small screwdriver which is a pain. Also don't throw that tiny screw driver away because its about the only way you can adjust the tones and balance. Its annoying and its not tamper proof, it is Dayton Audio reducing costs. I plan on somehow replacing or modifying those controls so I don't need to carry a screwdriver around with me.CONCLUSION: Its the only amp that can be bridged and it is powerful enough. Buy it if you need a small amp and want tone controls that work well.
Date published: 2015-08-09
Rated 5 out of 5 by from Mighty Midget!I needed a compact amp for an outdoor patio application. Signals are coming from an Apple Airport Express fed from my iTunes library. All my music is in Apple Lossless format and I am very particular about low distortion across the audio spectrum. My need calls for clean but not loud sound (neighbors!).Originally I bought Dayton's 60w/channel class T amp. which was a resounding disappointment (see my review). I asked PE to take it back, which they did without hesitation, via prepaid return shipping and a full credit. Thanks PE, no one can beat that for service.This 15w/channel mini class D amp, is more compact and leaves the 60w/channel class T in the dust in terms of sound quality and power. It works perfectly, and can play to very loud levels (not that I need that) without any noticeable distortion. It operates smoothly and cleanly across the full audio spectrum, with a wide range of program material and volume levels. This amp is solidly made and performs to a high standard. The moniker "Mighty Midget" seems totally appropriate.An added bonus is the tone controls, which can only be set with a screwdriver and so are not prone to tampering by kids, etc. Tone controls may be unique to this product in this class of compact amps. As it happens, I have found a little treble lift is quite beneficial in my setup, which will usually be played at quite a low volume setting.Based on my experience, I fully recommend this product. If you are even considering the 60w/channel class T, I'd say don't: Get this class D instead. You'll be glad you did.
Date published: 2015-07-19
Rated 2 out of 5 by from it sounds OK when soundsI bought this amp a month ago. Trying to use it in HF path of active speakers with BG Neo 3PDR (4 om, 90 db)as tweeter - it constantly goes auto-off if HF path runs less then 2 watts of power.I think this auto-off feature is a big design flaw. The funny thing is that the unit stays hot - not cool even if it was auto-off for a few hours. Seems like no other green feature except for the turning the output off and the red light going on, the unit stays internaly powered.
Date published: 2015-06-12
Rated 5 out of 5 by from Great little ampAfter looking at various small amplifiers, I settled on this one to improve the sound from our LCD TV. Paired with some good small speakers it does the job nicely. One of the features I needed was auto-on. This seems to be a hit or miss proposition on a lot of amplifiers but it works perfectly on this little amp.The other reason I selected this amp is the power rating, which I believe to be accurate at 15 WPC @ 4 Ohms, WITH LOW DISTORTION. Just for fun I ordered a Lepai 2020A+ to do some comparison. I used them both in a variety of setups. The Dayton DA30 is clearly in a totally different class. While the Lepai advertises a "clean 20WPC" it is QUICKLY left in the dust by the DA30. And, that's really to be expected given the price difference. The Lepai amp has a lot of features and does a good job for the price. Just don't be fooled into thinking it's anywhere near the DA30 in power and performance.
Date published: 2015-05-05
  • 2016-02-13T06:37CST
  • co_hasreviews, tv_0, tr_18
  • loc_en_US, sid_300-330, PRD, sort_mostRecent
Is there is a way to split in signal for adding powered sub to the "regular" 2 book shelf-size speakers B562? Can you describe exact set up with reference to parts including sub recommendations? Thanks!
Asked by: dimafishgo
Date published: 2016-01-14
we are a tax exempt private school.  How do I enter the tax exempt number to order?
Asked by: tina n
Please contact our sales and customer service for better help with this. sales@parts-express.com or 800-338-0531 x2.
Date published: 2015-09-03
Will this amp auto-switch between inputs if both the RCA input and the 3.5mm input are both plugged in at the same time?  Obviously I won't be sending an audio signal to both inputs at once but I'd like to switch between 2 different sources if possible.
Asked by: mac clinic
This uses a switched 3.5mm input, so once a 3.5mm plug is connected the RCA inputs will be automatically over ridden.
Date published: 2015-08-31
How would 24 VDC be supplied to this unit?
Asked by: RoadDawgBlues
The unit comes supplied with a 24 volt AC power adapter.
Answered by: GregT
Date published: 2015-06-09
If I use this for TV sound via headphone out jack which input would be better?  Headphone to RCA in via splitter or headphone to TRS IN?
Asked by: jaxtitleman
Both inputs will do the same thing and will not matter which you choose.
Date published: 2015-03-10
I'd like to purchase two of these units for use in a stereo wireless Bluetooth system. Can you recommend a Bluetooth receiver for each unit? Also, how do you set up the Bluetooth receivers to tell them which channel they are, that is LEFT or RIGHT
Asked by: ClassD Man
You would only need one Bluetooth receiver for both amps, you will just split the output from the receiver and send one channel into each amplifier. Our Saturn receiver is a nice small unit.http://www.parts-express.com/avantree-saturn-wireless-bluetooth-receiver-and-transmitter-featuring-aptx-codec--320-359
Date published: 2014-12-16
  • 2016-02-12T06:44CST
  • co_hasquestionsanswers, tq_17
  • loc_en_US, sid_300-330, PRD, sort_recentQuestionsFirst
Videos
