Dayton Audio DA270-8 10" Aluminum Cone Woofer
Brand:|Model: DA270-8|Part # 295-334
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion.
List Price$62.99
You Save22%
$49.35
Buy 5+$46.89
Part # 295-334
  • Great looking and sounding woofer
  • One-piece aluminum cone
  • Cosmetic stamped steel frame
  • Flat frequency response in passband region
  • Impressive output capabilities when used in MTM designs
  • Very low distortion
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion. When used with a well-designed crossover, an extremely flat frequency response can be achieved that is clean well into the midrange region.
  • Nominal Diameter10"
  • Power Handling (RMS)80 Watts
  • Power Handling (max)160 Watts
  • Impedance8 ohms
  • Frequency Response25 to 6,000 Hz
  • Sensitivity88.2 dB 2.83V/1m
  • Voice Coil Diameter1.42"
  • Magnet Weight53 oz.
  • Resonant Frequency (Fs)27.8 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)1.2 mH
  • Mechanical Q (Qms)1.95
  • Electromagnetic Q (Qes)0.55
  • Total Q (Qts)0.43
  • Compliance Equivalent Volume (Vas)3.83 ft.³
  • Mechanical Compliance of Suspension (Cms)0.64 mm/N
  • BL Product (BL)10.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)51.3g
  • Maximum Linear Excursion (Xmax)6.1 mm
  • Surface Area of Cone (Sd)346.4 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter10.63"
  • Baffle Cutout Diameter8.94"
  • Depth4.53"
  • Bolt Circle Diameter10.24"
  • # Mounting Holes5
  • Sealed Volume1.2 ft.³
  • Sealed F355 Hz
  • Vented Volume3.74 ft.³
  • Vented F330 Hz
  • BrandDayton Audio
  • ModelDA270-8
  • Part Number295-334
  • UPC844632087707
  • Product CategoryWoofers
    (12 Reviews)
  • Weight8.4 lbs.
View similar products to the Dayton Audio DA270-8 10" Aluminum Cone Woofer
