Dayton Audio DA175-8 7" Aluminum Cone Woofer
Brand:|Model: DA175-8|Part # 295-335
7" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap.
List Price$36.99
You Save23%
$28.58
Buy 4+$27.22
Part # 295-335
  • Special composite dustcap
  • Stamped steel frame provides a very high-class and professional look
  • Aluminum cone offers a flat frequency response in the passband region with very low distortion
7" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap. The cosmetic stamped steel frame provides a very high-class and professional look to your next speaker design. The aluminum cone offers a flat frequency response in the passband region with very low distortion.
  • Nominal Diameter7"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response35 to 10,000 Hz
  • Sensitivity85 dB 2.83V/1m
  • Voice Coil Diameter1.38"
  • Resonant Frequency (Fs)39 Hz
  • DC Resistance (Re)5.9 ohms
  • Voice Coil Inductance (Le)1.14 mH
  • Mechanical Q (Qms)3.31
  • Electromagnetic Q (Qes)0.7
  • Total Q (Qts)0.58
  • Compliance Equivalent Volume (Vas)0.58 ft.³
  • Mechanical Compliance of Suspension (Cms)0.66 mm/N
  • BL Product (BL)7.17 Tm
  • Diaphragm Mass Inc. Airload (Mms)25.17g
  • Maximum Linear Excursion (Xmax)4.25 mm
  • Surface Area of Cone (Sd)132.7 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter6.91"
  • Baffle Cutout Diameter5.67"
  • Depth3.19"
  • Bolt Circle Diameter6.54"
  • # Mounting Holes5
  • Sealed Volume0.46 ft.³
  • Sealed F357 Hz
  • Vented Volume1.2 ft.³
  • Vented F328 Hz
  • BrandDayton Audio
  • ModelDA175-8
  • Part Number295-335
  • UPC844632000300
  • Product CategoryWoofers
    (34 Reviews)
  • Weight3.4 lbs.
View similar products to the Dayton Audio DA175-8 7" Aluminum Cone Woofer
Dayton Audio DA175-8 7" Aluminum Cone Woofer is rated 4.5882 out of 5 by 34.
Rated 5 out of 5 by from Great speaker for a great price!I bought a pair of these to refurbish an old Yamaha YST-SW120 subwoofer. They have made it sound better than when it was new! I mostly listen to jazz and instrumental music with a lot of double bass and it is amazing how much better it sounds! I have it paired with some M-Audio AV40 studio monitors and the combination is excellent for near field listening! I have the subwoofer crossed over at its highest level- 140Hz so the DA175-8s take over some of the woofer duty as well. Perfect fit and great sound! Also excellent for movies. Thanks!!!
Date published: 2014-12-03
Rated 5 out of 5 by from Great Value!I bought this to replace the speaker in my Klipsch 2.1 sub-woofer. The Dayton DA175-8 7" fit right in the woofer box hole. The only modification was to redrill for 5 holes for the new woofer and put a new larger quick connector for the ground to fit the speaker. Due to the slightly different design of this speaker the grill will not fit back on the enclosure without some modification. The sub-woofer looks great without the grill so I'm leaving it that way.
Date published: 2014-11-13
Rated 5 out of 5 by from More Zaph BAMTMsLike several other reviewers I used these to build a pair of Zaph Audio's "Bargain Aluminum MTMs." They're crossed to Seas 27TBFCG tweeters and paired with DIY sealed stereo subs using Dayton's RSS315HF 12" drivers. They are as clean and accurate as any spealers I've ever heard. See the nearfield FR/THD plot using REW (MTM only, sub not included).
Date published: 2014-08-11
Rated 5 out of 5 by from Great WooferI built a pair of Schumakubin MKIIs recently, and these are spectacular as a woofer and as a mid. Paired with a Dayton RS28F this is what a speaker is supposed to sound like as far as I'm concerned. Very correct and lots of output.
Date published: 2014-06-19
Rated 5 out of 5 by from Klipsch PC 2.1 and 5.1 woffer repacementBlew my Klipsch 2.1 and 5.1 woofers out. 2.2 has 1 woofer, 5.1 has 2. Dayton DA175-7 7" fit right in the woofer box holes. The only modification was to redrill for 5 holes for the new woofers and put a one new larger quick connector for the ground to fit the speaker. Very simple. Also bend the screens out with pliers to snap into the woof box. 10 minutes done. Sounds much better than ever. and saved hundreds.
Date published: 2014-05-03
Rated 5 out of 5 by from Amazing sound quality!First off, I give a solid 10/10 when you factor in value, price, and extremely high sound quality. I bought four of these for a pair of speakers I was building (2 per speaker cabinet) and now that it's all done, let me just say, these are your speakers. tight bass, clear mids, and good, clean highs (these go up to about 10,000 Hz). Paired with a 2" paper cone tweeter and a 4,500 Hz crossover, your woofer shopping stops here.
Date published: 2014-04-01
  • 2016-02-10T06:39CST
  • co_hasreviews, tv_0, tr_34
  • loc_en_US, sid_295-335, PRD, sort_mostRecent
I just purchased two of these woofers to install in a 0.9 cu ft. enclosure. Can you please tell me the optimum port size and tuned frequency? Thanks.
Asked by: Footsie
Are you wanting both woofers in that volume, or just one?
Date published: 2015-12-11
Can I use a pair of these (2 drivers per cabinet) as woofers in your 300-7066 cabinets?  I plan on keeping the cabinets sealed and using a 6.5" coax car driver for the mids and highs.  I already have the car drivers.  Trying to keep the budget low.
Asked by: 54Chevy
Yes a pair of these will work well in that volume sealed.
Date published: 2015-09-29
I need a relatively low cost replacement for a Polk MW 7100. Would the Dayton do the trick or is there a better option?
Asked by: angus bubba
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Answered by: MattW
Date published: 2015-08-07
Given the extended range of this woofer, which Dayton crossover would you recommend with the DC28FT-8 tweeter? I'm going to experiment with this combination in a Realistic Optimus 27 speaker system.
Asked by: mfenberg
I would recommend using a cross over point of 2 KHz or higher so you can use one like part 260-140.
Answered by: MattW
Date published: 2015-04-22
I have 2 of these and would like to use them for a subwfr application (<30hz desired). ~100 wpc amp 1) How do I determine the best box size/port dimensions/tuning etc? 2) cani use both of them in one enclosure working together? or do 2 separate subs?
Asked by: stevebu
Two separate subs are almost always better than one, but it really is application specific. These are able to be tuned relatively low, but will be limited with overall output capability. I would recommend a volume of 1.25 cubic feet per woofer, with a 2" diameter, 6" long port for a tuning frequency of 29 Hz and F3 of 26 Hz. Keep an eye on woofer excursion, these wont take much more than about 20 watts without having problems.
Date published: 2014-12-18
I am considering using a pair of these to replace two 7" drivers in a Yamaha subwoofer model YST-SW120. Crossover adjustable up to 140Hz. The cabinet is 1.6 cu ft. Port is 10" long with 3" diameter. Workable? Suggestions? Thanks!
Asked by: Colorado_al
These will work quite well in that application. It looks like your tuning frequency would be 30 Hz.
Date published: 2014-12-01
  • 2016-02-10T07:38CST
  • co_hasquestionsanswers, tq_21
  • loc_en_US, sid_295-335, PRD, sort_recentQuestionsFirst
