Dayton Audio DA135-8 5-1/4" Aluminum Cone Woofer
Brand:|Model: DA135-8|Part # 295-330
5-1/4" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap.
List Price$27.99
You Save23%
$21.54
Buy 4+$20.51
Part # 295-330
  • Makes a great studio monitor speaker
  • Aluminum cone offers a flat frequency response
  • Cosmetically appealing integrated trim ring
  • Very low distortion driver
5-1/4" aluminum cone woofer with rubber surround, flat spider, and special composite dustcap. The cosmetic stamped steel frame provides a very high-class and professional look to your next speaker design. The aluminum cone offers a flat frequency response in the passband region with very low distortion.
  • Nominal Diameter5-1/4"
  • Power Handling (RMS)30 Watts
  • Power Handling (max)60 Watts
  • Impedance8 ohms
  • Frequency Response50 to 15,000 Hz
  • Sensitivity85 dB 2.83V/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)56.5 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.97 mH
  • Mechanical Q (Qms)2.61
  • Electromagnetic Q (Qes)0.68
  • Total Q (Qts)0.54
  • Compliance Equivalent Volume (Vas)0.26 ft.³
  • Mechanical Compliance of Suspension (Cms)0.93 mm/N
  • BL Product (BL)5.32 Tm
  • Diaphragm Mass Inc. Airload (Mms)8.54g
  • Maximum Linear Excursion (Xmax)3 mm
  • Surface Area of Cone (Sd)75.4 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter5.31"
  • Baffle Cutout Diameter4.39"
  • Depth2.48"
  • Bolt Circle Diameter4.96"
  • # Mounting Holes4
  • Sealed Volume0.16 ft.³
  • Sealed F389 Hz
  • Vented Volume0.47 ft.³
  • Vented F344 Hz
  • BrandDayton Audio
  • ModelDA135-8
  • Part Number295-330
  • UPC844632000294
  • Product CategoryWoofers
    (13 Reviews)
  • Weight1.97 lbs.
View similar products to the Dayton Audio DA135-8 5-1/4" Aluminum Cone Woofer
