Dayton Audio DA115-8 4" Aluminum Cone Woofer
Brand:|Model: DA115-8|Part # 295-328
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion.
List Price$20.99
You Save23%
$16.13
Buy 4+$14.67
Part # 295-328
  • Great looking and sounding woofer
  • Cosmetic stamped steel frame
  • Flat frequency response in passband region
  • Impressive output capabilities when used in MTM designs
  • Very low distortion
The aluminum cone on this driver is extremely rigid yet well damped, making the bass and midbass region very clean and low in distortion. When used with a well-designed crossover, an extremely flat frequency response can be achieved that is clean well into the midrange region.
  • Nominal Diameter4"
  • Power Handling (RMS)20 Watts
  • Power Handling (max)40 Watts
  • Impedance8 ohms
  • Frequency Response60 to 15,000 Hz
  • Sensitivity84.9 dB 2.83V/1m
  • Voice Coil Diameter2"
  • Resonant Frequency (Fs)60 Hz
  • DC Resistance (Re)6.4 ohms
  • Voice Coil Inductance (Le)0.7 mH
  • Mechanical Q (Qms)2.6
  • Electromagnetic Q (Qes)0.49
  • Total Q (Qts)0.41
  • Compliance Equivalent Volume (Vas)0.155 ft.³
  • Mechanical Compliance of Suspension (Cms)1.1 mm/N
  • BL Product (BL)5.7 Tm
  • Diaphragm Mass Inc. Airload (Mms)6.6g
  • Maximum Linear Excursion (Xmax)2.5 mm
  • Surface Area of Cone (Sd)53.1 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Voice Coil FormerAluminum
  • Magnet MaterialFerrite
  • Overall Outside Diameter4.55"
  • Baffle Cutout Diameter3.66"
  • Depth2.26"
  • Bolt Circle Diameter4.21"
  • # Mounting Holes4
  • Sealed Volume0.04 ft.³
  • Sealed F3125 Hz
  • Vented Volume0.13 ft.³
  • Vented F368 Hz
  • BrandDayton Audio
  • ModelDA115-8
  • Part Number295-328
  • UPC844632081675
  • Product CategoryWoofers
    (15 Reviews)
  • Weight2 lbs.
View similar products to the Dayton Audio DA115-8 4" Aluminum Cone Woofer
