Dayton Audio D250P-8 1" Polyimide Compression Horn Driver
Brand:|Model: D250P-8|Part # 270-402
The Dayton Audio D250P-8 compression driver features a polyimide diaphragm for a smooth character and rich detailed sound. A true rear-diaphragm design with advanced phase plug provides low distortion and excellent sonic detail.
List Price$69.99
You Save29%
$49.95
Buy 4-19 $47.35
Buy 20+$44.89
Part # 270-402
  • 1,000-20,000 Hz frequency response
  • Optimized ferrite motor structure
  • Polyimide diaphragm for smooth, detailed reproduction
  • High sensitivity and power handling
  • 2-bolt/3-bolt mounting for a variety of applications
The D250P-8 compression driver from Dayton Audio delivers sonic accuracy, power, and detail, thanks to an optimized acoustic and electromechanical design. Its robust ferrite motor is powerful yet economical, providing extended high frequency response and incredible dynamic impact. The precision polyimide diaphragm assembly is field-replaceable and features nickel-plated, spring-loaded push terminals for pro-grade serviceability.
Designed for demanding professional audio, custom cinema, or high-efficiency home audio applications, this driver is a full-spectrum performer and a true high-value choice.  A 2-bolt/3-bolt mount design allows the D250T-8 to be used with many popular horns. Please see the Related Items section for the replacement diaphragm. Mounting hardware is included.
Specifications: • Power handling: 60 watts RMS/120 watts with minimum crossover of 1.6 kHz/12 dB slope • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-20,000 Hz • SPL: 104 dB 1W/1m • Dimensions: 4.7" diameter x 2.2" depth • Net weight: 4.5 lb.
  • Mounting Type2-Bolt/3-Bolt
  • Exit Diameter1"
  • Diaphragm MaterialKapton / Polyimide
  • Impedance8 ohms
  • Power Handling (RMS)60 Watts
  • BrandDayton Audio
  • ModelD250P-8
  • Part Number270-402
  • UPC848791000010
  • Product CategoryHorn Drivers
    (1 Reviews)
  • Weight4.45 lbs.
View similar products to the Dayton Audio D250P-8 1" Polyimide Compression Horn Driver
in the Horn Drivers product category.
Dayton Audio D250P-8 1" Polyimide Compression Horn Driver is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from PhenominalI am working on a horn speaker project using all Dayton components. The one thing I was lacking was an HF driver, that had high enough sensitivity to keep up with the rest of drivers. Then low and behold I see Dayton compression drivers in the new products directory. After a quick comparison of specs I chose to give the Polymide driver a shot. Overall I am very pleased with the sound and performance of this driver, and will continue to use it in my future projects.
Date published: 2012-11-27
  • 2016-02-12T06:26CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_270-402, PRD, sort_mostRecent
Will these keep up in a 3-way setup with an Eminence 3015 (non LF) and an 18 Sound 6ND410 mid when mounted on a Faital Pro STH100 horn and crossed over around 3k? Thanks.
Asked by: SonicXtasy
Yes these will have no issues keeping up in a system like that crossed at 3k.
Date published: 2016-01-20
O.K., I'll re-phrase the question. Tech data sheet lists spl as 104 dB 1W/1M (therefore maybe approx. 105 dB 2.83v/1M) while freq response chart (on h812 horn) indicates 108 dB @1M +/- 2dB from 1-10khz. Please clarify.
Asked by: RichZ
Different horns will have different effects on the sensitivity of a compression driver. The H812 is a constant-directivity horn with a throat section that provides more gain. The SPL listed is a plane-wave sensitivity and will change with whatever horn you decide to use the driver with. You will need to measure the compression driver on your horn of choice, and then use that data to develop the crossover design that will properly integrate the woofer and HF horn. Another way to integrate the two is to use an L-Pad after the crossover but before the compression driver to make the horn "adjustable" for whatever sound reinforcement situation you find yourself in.
Answered by: DaytonAudio_Rory
Date published: 2015-08-03
The frequency response chart for the d250p-8 specifies the horn used (h812) and that the measurement was taken at l m distance, but voltage drive level is not indicated--what voltage drive level was used to generate this chart? Thanks.
Asked by: RichZ
Voltage level for all Dayton Audio measurements is 2.83V/1m (except for some very small drivers in the CE-series that might be damaged by 1-watt input).
Date published: 2015-02-17
I have 2 of these drivers in my setup, each produce a static noise that can only be heard at low volume, just loud enough to be annoying. I've run them on different amplifiers and audio sources so it is the drivers fault. Any way to fix this?
Asked by: tyler99
Keep in mind that these are very high sensitivity tweeters, so if there is any hiss or AC line hum or buzz, it may be reproduced at a higher level through these tweeters than it would be from a typical dome or cone tweeter. If the noise is only noticeable when music is playing, be sure that you are operating these drivers with a crossover of 2000 Hz or higher, and if yes, then it is possible that one or both of the voice coils may be rubbing against the sides of the magnetic gap. This can be solved by replacing the diaphragms, or returning both complete drivers for warranty replacement. Alternately you may be able to remove the rear cover of the compression driver and attempt to center the diaphragms yourself, but when properly seated, the diaphragm voice coils should be centered in the magnetic gap. Before you attempt this, however, be sure the magnetic gap is clear of any metal pieces that could be causing the noise.
Date published: 2015-02-02
Can I wire this driver in parallel with the titanium version of this? One of each. Or will this give problems in responce/ powerhandling/ etc.?
Asked by: leonveek
You can use the polyimide driver and the titanium driver in parallel with no problems if desired. The only difference between the drivers is the diaphragm material.
Date published: 2014-12-01
Will this work with with this waveguide?         http://www.parts-express.com/community-1-exponential-horn-90x40-non-standard-2-bolt-for-uc1-compression-driver--299-522
Asked by: justwonder
Unfortunately no, the bolt spacing on the horn is 91mm and is a proprietary fit for the Community UC-1 driver.
Date published: 2014-06-30
  • 2016-02-12T06:53CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_270-402, PRD, sort_recentQuestionsFirst
Videos
