Dayton Audio CS620W 6-1/2" 2-Way In-Wall Speaker Pair
Brand:|Model: CS620W|Part # 300-036
You won't believe how good the Dayton Audio CS620W 6-1/2" 2-way in-wall speakers really sound! They're big enough to produce great home theater audio reproduction, and yet still fit everyone's budget.
List Price$90.99
You Save23%
$69.75
Buy 4-11 $62.88
Buy 12+$59.80
Part # 300-036
  • Affordable high fidelity sound from an easy to install speaker
  • Great for front or rear speakers in your surround system
  • Best value in the industry
  • Clear and detailed 1" Mylar dome tweeter
  • 6-1/2" polypropylene woofer is accurate and reliable
The Dayton Audio CS620W 2-way speaker pair is not only our most popular in-wall speaker, it's affordable enough to install in every room of your house. The 6-1/2" polypropylene woofer and 1" Mylar dome tweeter were specially designed to produce a warm, rich home theater sound. The crossover network utilizes Mylar capacitors to achieve the best possible high frequency fidelity. A three-piece bracket design make installation in new or existing walls a snap.
Specifications: • Power handling: 60 watts RMS/85 watts max • 8 ohm impedance • 3 component L/C crossover network • Frequency response: 50-20,000 Hz • Sensitivity: 89 dB 1W/1m • Overall dimensions: 8-1/2" W x 12" L x 3-1/2" D • Hole size: 7-1/4" x 10-3/4" • Fits into standard 2" x 4" wall • Sold in pairs.
  • Configuration2-Way
  • Woofer Diameter6-1/2"
  • BrandDayton Audio
  • ModelCS620W
  • Part Number300-036
  • UPC844632000447
  • Product CategoryIn-Wall Speakers
  • Unit of MeasurePR
    (37 Reviews)
  • Weight8.7 lbs.
View similar products to the Dayton Audio CS620W 6-1/2" 2-Way In-Wall Speaker Pair
in the In-Wall Speakers product category.
Dayton Audio CS620W 6-1/2" 2-Way In-Wall Speaker Pair is rated 4.3514 out of 5 by 37.
Rated 1 out of 5 by from Blown in a month.I've had these for a month and they're both blown. They're not over or under powered. I wish I would have spent the extra money for better quality. Very frustrated with these speakers as fronts in a fresh new house. Still love PartsExpress, but I've learned a lesson.
Date published: 2015-10-12
Rated 5 out of 5 by from Product and ServiceThank you for delivering my speakers in a timely matter. I am more than satisfied with the Service and the Product. Thank you
Date published: 2015-05-31
Rated 5 out of 5 by from Excellent SpeakersI bought a set of Dayton speakers a number of years ago to put in the wall of a sun room we were building. My expectations were pretty low, but the speakers sound fantastic. This time I went with a less expensive set for a TV in my game room. Again, no disappointment! These are really nice sounding speakers and pretty easy install (as long as you notice that there is a top and bottom to the mounting bracket. Highly recommended.
Date published: 2014-09-12
Rated 5 out of 5 by from Excellent surroundsI was rebuilding my HT and decided that to save space I would do in walls for surrounds. The price on these was great and the reviews were not wrong. I wasn’t expecting a lot from an in wall speaker but these sound great! Easy to mount and look good. I watch movies loud and they have never distorted in any way. If I ever add channels to my HT setup I'll buy more.
Date published: 2012-10-19
Rated 4 out of 5 by from Decent Set Of Cheap In-WallsInstallation was easy enough. Getting the wire there is the hard part. If you can read a tape measure and a level, these will be a walk in the park to install. The baffles warp easily so watch the screw torque. Overtightening makes the grille fit tight, or not at all.Sound quality out of the box is annoyingly shrill.STOP READING HERE. DO NOT TRY THIS AT HOME! Padding the tweeters by 6dB makes them sound much better. Unfortunately, making them sound better voids the warranty, but at the price, who cares? Just insert a 10 Watt, 8 ohm resistor between the input side of the tweeter's filter and the amplifier connection.
Date published: 2012-05-05
Rated 4 out of 5 by from Dayton CS620W In-Wall SpeakersI purchased these to install in a bathroom. They are driven from a AudioSource AMP100 amplifier which autodetects a signal from an Apple Aitport Express. The speakers sound ok although they are a little 'bright' for my taste. The same amp is also driving some Wharfdale bookself speakers in the bedroom that sounds much better. As mentioned in other reviews, the install method isn't very good. I chose to make a much smaller hole and uses double sided tape to secure the metal mount to the inside of the drywall while I screwed on the front panel. The grill is VERY HARD to remove once installed and will likely damage my paint job when I do. So, for the money, a nice set of speakers, but you have to ignore the installation instructions for a better fit.
Date published: 2012-02-28
  • 2016-02-05T06:16CST
  • co_hasreviews, tv_0, tr_37
  • loc_en_US, sid_300-036, PRD, sort_mostRecent
Can I use one of these for a center speaker as well.  I need a total of 5, if they will work for that as well. Thank you
Asked by: pacificpro
It is certainly valid to use the exact same speaker in all positions. Some experts will actually argue that is the best setup as the timbre remains the same from all locations.
Answered by: Chrisf
Date published: 2016-01-26
What are the dimensions of the black metal bracket that is used to mount the speakers? The cutout size says 7-1/4 and I only have up to 7-1/2 inches to mount the speakers. Is the bracket bigger than this?
Asked by: Buller6497
The bracket is the same width as the cutout (7-1/4") but it is the same overall height (12") as the front of the speaker.
Date published: 2015-12-09
what does buy 4-11 mean, and what does by 12-up mean?
Asked by: shirley62
That is referring to a quantity discount. If you buy more than 4 pairs, there is a discount. There is an additional discount if you buy more than 12 pairs.
Answered by: Chrisf
Date published: 2015-04-07
I want to use these for a 5.1 set up, wondering how well one would work acting as the center channel.  Or is there any other suggestions ?  I am concerned on the appearance of the frames to be similar.
Asked by: Mark Mark
One of these would work well as the center channel as long as it is mounted vertically.
Date published: 2015-02-25
Can you paint the front edges of the speaker (not the grill)? If so, how might I do this to not damage the speaker?
Asked by: brianjlowry
Yes the edges can be painted to match any decor. You will have to tape and mask off the rest of the speaker in order to not damage anything. We recommend spraying them to apply the paint.
Is the tweeter directional i.e., can it be pointed at an angle?
Asked by: gwa1
Unfortunately these tweeters do not swivel.
Date published: 2014-07-10
  • 2016-02-05T06:58CST
  • co_hasquestionsanswers, tq_14
  • loc_en_US, sid_300-036, PRD, sort_recentQuestionsFirst
