Dayton Audio CS620CT 6-1/2" 2-Way 70V Ceiling Speaker Pair
Brand:|Model: CS620CT|Part # 300-400
Don't let the low cost fool you! These great sounding ceiling speakers are ideal for adding music to restaurants, offices, or industrial ares!
List Price$73.99
You Save24%
$56.42
Buy 4+$51.81
Part # 300-400
  • 6-1/2" carbon fiber woofer
  • 1" mylar tweeter
  • Easy installation
  • Add music to the kitchen, den, bath, or patio!
  • 5 Year Warranty
Don't let the low cost fool you! These great sounding ceiling speakers are ideal for adding music to restaurants, offices, or industrial ares! They feature a weather resistant 6-1/2" carbon fiber cone with a butyl rubber surround and a coaxial mounted 1" mylar dome tweeter and a 70V transformer tapped at 0.62W, 1.25W, 2.5W, 5W, and 10W. Perfect for high moisture, these speakers can hold their own against most environments. Retrofit design allows installation in both new and existing construction in just minutes. System includes removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions.
*Note: Remove and discard the 1/8" perforated ring that connects the center "painting grill mask" and the outer "mounting template" before attempting to use the templates.
Specifications: • 70V tap settings: 0.62W, 1.25W, 2.5W, 5W, 10W, 8 Ohm • Frequency response: 60-20,000 Hz • SPL: 88 dB 1W/1m • Dimensions: 8-1/2" dia. x 2-3/4" D • Cutout size: 7-3/8" dia. • Sold in pairs.
  • Input Rating70V
  • Mounting StyleIn-ceiling
  • Special FeaturesWeather Resistant
  • Woofer Diameter6-1/2"
  • BrandDayton Audio
  • ModelCS620CT
  • Part Number300-400
  • UPC844632065040
  • Product CategoryIn-Ceiling / On-Ceiling Speakers
  • Unit of MeasurePR
    (4 Reviews)
  • Weight8 lbs.
View similar products to the Dayton Audio CS620CT 6-1/2" 2-Way 70V Ceiling Speaker Pair
in the In-Ceiling / On-Ceiling Speakers product category.
Dayton Audio CS620CT 6-1/2" 2-Way 70V Ceiling Speaker Pair is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from Great SpeakersThese speakers work great we use them often in conference rooms and other 70v applications. They sound good for the $.
Date published: 2013-08-15
Rated 5 out of 5 by from Very nice for the price!I installed 14 of these in a restaurant. The owner was very happy with the sound quality. I think it's safe to say with these speakers, you actually get a little more than what you pay for.
Date published: 2010-02-19
Rated 5 out of 5 by from Nice for the price!I installed ten of these speakers in a local massgae parlor. They needed background music throughout the building and these work like a charm.
Date published: 2009-07-10
Rated 4 out of 5 by from Installed 10 in a restaurant expansionThese seem like nice speakers. A few minor quibbles.1. The instructions are for the 8ohm version. It would be better if they had the transformer tap color code written somewhere because of the way the leads are bound. It is not very easy to determine which lead goes to what power setting.2.When you use the hole marking templates, it would have been nice to know that in order to get a correct fit, you should cut on the outside of the pencil line, by at least 1/16"
Date published: 2008-03-04
  • 2016-02-14T06:43CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_300-400, PRD, sort_mostRecent
I saw the bridge cut-out hole is 7.5".  Is that the suggested cut-out for in-wall mount without a bridge?  Also, what is the depth of this speaker?
Asked by: BKM1
The cutout for these without the bridge is 7-3/8", the depth is 2-3/4".
Date published: 2014-08-04
Is there a compatible tile bridge available?
I see the Plenum kit (Part #300-401) but that's a bit pricey if I don't have a plenum space but do have drop-tile.
Asked by: psantucc
The bridge alone from part number 300-401 is part number 300-311 and it will fit those speakers.
Date published: 2013-02-06
  • 2016-02-14T07:59CST
  • loc_en_US, sid_300-400, PRD, sort_recentQuestionsFirst
