Dayton Audio CS420ECT 4" 2-Way Enclosed Ceiling Speaker 70V
Brand:|Model: CS420ECT|Part # 300-414
Don't let the small size fool you…. These 4" enclosed ceiling speakers are dual tuned ported, which adds that little extra thump that is missing on open back ceiling speakers. Also, these are perfect for mounting in ceilings that have an attic above with blown-in insulation.
List Price$64.99
You Save23%
$49.89
Buy 4-11 $41.89
Buy 12+$39.80
Part # 300-414
  • 4" coated poly cone woofer
  • Mylar tweeter
  • 70 Volt transformer is easily accessible from the front
  • UL94 high temperature rated enclosure
  • Gold plated spring loaded binding posts
Don't let the small size fool you…. These 4" enclosed ceiling speakers are dual tuned ported, which adds that little extra thump that is missing on open back ceiling speakers. Also, these are perfect for mounting in ceilings that have an attic above with blown-in insulation. Expect great sound for years from these speakers for years to come. UL94 high temperature rated enclosure. System includes: one speaker, removable steel mesh grills, built-in mounting brackets, hardware, and installation instructions. Sold individually.
*Note: Remove and discard the 1/8" perforated ring that connects the center "painting grill mask" and the outer "mounting template" before attempting to use the templates.
Specifications: • Power handling: 20 watts RMS/40 watts max • Frequency response: 60-20,000 Hz • SPL: 86 dB 1W/1m • 70V transformer tap settings: 2W, 4W, 8W, 16W, 8 Ohm • Dimensions: 8-1/2" dia. x 5-7/8" D • Cutout size: 6-5/8" dia.
  • Input Rating70V
  • Mounting StyleIn-ceiling
  • Special FeaturesEnclosed Back
  • Woofer Diameter4"
  • BrandDayton Audio
  • ModelCS420ECT
  • Part Number300-414
  • UPC844632000485
  • Product CategoryCeiling Speakers
    (2 Reviews)
  • Weight4.2 lbs.
View similar products to the Dayton Audio CS420ECT 4" 2-Way Enclosed Ceiling Speaker 70V
in the Ceiling Speakers product category.
Dayton Audio CS420ECT 4" 2-Way Enclosed Ceiling Speaker 70V is rated 4.5 out of 5 by 2.
Rated 4 out of 5 by from easy installthese are easy to install -- the speaker is completely enclosed (no damage worries), the mounting screws are captured and give a solid hold when tightened; and the connector posts are spring-loaded so you don't have to worry about soldering or loose screws.
Date published: 2008-12-09
Rated 5 out of 5 by from I love them like a child loves candy!Easy to install. great price. I bought them for the tap setting right next to the cone saving me time to pull the speaker out of the ceiling to change wattage tap. I used mine at 4 watts. Also has 8ohm setting. Sounds great in a mall bathroom :)Does not come with black goo to hold grill in, but is a flanged grill that applies pressure to the side of the enclosure to hold it up. Not as secure in my opinion, but much easier to remove!
Date published: 2008-06-30
  • 2016-02-06T06:45CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-414, PRD, sort_mostRecent
What is the minimum depth needed above the finished face of a ceiling to install this speaker?
Asked by: Andrew36
The depth of this speaker is 5-7/8 inches.
Answered by: Chrisf
Date published: 2016-02-03
Does it come with or is a tile bridge available for it? If bridge is separate what does it cost I am looking at 45 speakers and 14 need tile bridge.
Asked by: scottytman
These do not include tile bridges and unfortunately we do not have bridges available for them separately.
Date published: 2015-12-15
Is there a pre-installation bracket available for new construction?
Asked by: Paul62
Unfortunately we do not have any pre-construction brackets available at this time.
Date published: 2015-09-24
how much is the impedance?
Asked by: soso
This is a 70v speaker and is intended to be used with a 70v amplifier. It does have an 8 ohm bypass selection however you will be farther ahead purchasing the speaker without the transformer option to begin with.
Date published: 2012-09-04
  • 2016-02-06T07:43CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_300-414, PRD, sort_recentQuestionsFirst
