285-123_ALT_0
Dayton Audio CE Series CE90-50P-8 3-1/2" x 2" Full Range Driver
Brand:|Model: CE90-50P-8|Part # 285-123
Dayton Audio’s CE90-50P-8 is an economical small full-range driver that features a narrow racetrack shape, a shielded ceramic magnet motor, a paper cone, a front gasket, and a steel frame. 8 ohm impedance.
  • Paper cone with fabric roll surround for high efficiency
  • Rugged stamped steel frame
  • Shielded ceramic magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8”) to 90 mm (3-1/2”) in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE70-30P-8 features a popular ‘racetrack’ shape that maximizes cone area for high output while fitting into narrow spaces. Its high-quality design features a paper cone, coated fabric surround, textile spider, shielded ceramic motor, and a rectangular steel frame with mounting lobes for conventional mounting.
  • Nominal Diameter2" x 3"
  • Power Handling (RMS)5 Watts
  • Power Handling (max)10 Watts
  • Impedance8 ohms
  • Frequency Response324 Hz
  • Sensitivity87 dB 2.83V/1m
  • Voice Coil Diameter0.51"
  • Resonant Frequency (Fs)324 Hz
  • DC Resistance (Re)7 ohms
  • Voice Coil Inductance (Le)0.36 mH
  • Mechanical Q (Qms)4.72
  • Electromagnetic Q (Qes)3.89
  • Total Q (Qts)2.13
  • Mechanical Compliance of Suspension (Cms)0.2 mm/N
  • BL Product (BL)2.12 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.21g
  • Maximum Linear Excursion (Xmax)0.8 mm
  • Surface Area of Cone (Sd)20.84 cm²
  • Cone MaterialPaper
  • Surround MaterialCloth
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.00" x 3.56"
  • Baffle Cutout Diameter1.72" x 3.22"
  • Depth1.67"
  • # Mounting Holes4
  • BrandDayton Audio
  • ModelCE90-50P-8
  • Part Number285-123
  • UPC848791000409
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.45 lbs.
View similar products to the Dayton Audio CE Series CE90-50P-8 3-1/2" x 2" Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
