285-119_ALT_0
Dayton Audio CE Series CE70-30P-8 1-1/4" x 2-3/4" Full Range Driver
Brand:|Model: CE70-30P-8|Part # 285-119
Dayton Audio’s CE40P-8 is an economical small full-range driver that features an ultra-narrow racetrack shape, a high-output neodymium motor, a paper cone, a front gasket, and a steel frame. 8 ohm impedance.
List Price$5.99
You Save32%
$4.10
Buy 100+$2.79
Part # 285-119
  • Paper cone with foam surround for high output
  • Rugged stamped steel frame
  • High-energy neodymium magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE70-30P-8 features a ‘racetrack’ design that maximizes cone area for high output while fitting into narrow spaces. Its high-quality design features a paper cone, foam surround, textile spider, high-performance neodymium motor, and a rectangular steel frame with mounting lobes for conventional mounting.
  • Nominal Diameter1" x 2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance8 ohms
  • Frequency Response310 to 20,000 Hz
  • Sensitivity85 dB 2.83V/1m
  • Voice Coil Diameter0.52"
  • Resonant Frequency (Fs)371 Hz
  • DC Resistance (Re)7.2 ohms
  • Voice Coil Inductance (Le)0.21 mH
  • Mechanical Q (Qms)5.65
  • Electromagnetic Q (Qes)5.67
  • Total Q (Qts)2.83
  • Mechanical Compliance of Suspension (Cms)0.23 mm/N
  • BL Product (BL)1.56 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.82g
  • Maximum Linear Excursion (Xmax)0.8 mm
  • Surface Area of Cone (Sd)11.04 cm²
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.18" x 2.76"
  • Baffle Cutout Diameter1.00" x 2.52"
  • Depth0.76"
  • BrandDayton Audio
  • ModelCE70-30P-8
  • Part Number285-119
  • UPC848791000386
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
  • Weight0.065 lbs.
View similar products to the Dayton Audio CE Series CE70-30P-8 1-1/4" x 2-3/4" Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
