285-111_ALT_0
Dayton Audio CE Series CE52P-4 2" Paper Full Range Driver
Brand:|Model: CE52P-4|Part # 285-111
Dayton Audio’s CE52P-4 is an economical small full-range driver. It features a high-output neodymium motor, a lightweight paper cone, rubber surround, and rugged stamped frame for conventional mounting. 4 ohm impedance.
  • Paper cone and rubber surround for extended bass
  • Rugged deep-draft stamped steel frame
  • High-energy double neodymium magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE52P-4 provides exceptional range with high output, plus features you’d expect from a much larger driver. Its high-quality design features a paper cone, rubber surround, high-performance dual-magnet neodymium motor, and an injection-molded frame with gasket for conventional front or rear mounting. It’s the perfect choice for multimedia applications, hi-fi line arrays, or compact loudspeakers.
  • Nominal Diameter2"
  • Power Handling (RMS)3 Watts
  • Power Handling (max)6 Watts
  • Impedance4 ohms
  • Frequency Response220 to 20,000 Hz
  • Sensitivity86 dB 2.83V/1m
  • Voice Coil Diameter0.8"
  • Resonant Frequency (Fs)226 Hz
  • DC Resistance (Re)3.05 ohms
  • Voice Coil Inductance (Le)0.12 mH
  • Mechanical Q (Qms)8.5
  • Electromagnetic Q (Qes)1.16
  • Total Q (Qts)1.02
  • Mechanical Compliance of Suspension (Cms)0.33 mm/N
  • BL Product (BL)2.37 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.44g
  • Maximum Linear Excursion (Xmax)1 mm
  • Surface Area of Cone (Sd)11.34 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.97"
  • Baffle Cutout Diameter1.7"
  • Depth1.04"
  • # Mounting Holes4
  • BrandDayton Audio
  • ModelCE52P-4
  • Part Number285-111
  • UPC848791000461
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight0.124 lbs.
View similar products to the Dayton Audio CE Series CE52P-4 2" Paper Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
