Dayton Audio CE Series CE46P-4 1-7/8" Paper Full Range Driver
Brand:|Model: CE46P-4|Part # 285-109
Dayton Audio’s CE46P-4 is an economical small full-range driver with surprising range. It features a high-output neodymium motor, a lightweight paper cone, a front gasket, and an injection-molded frame. 4 ohm impedance.
  • Paper cone and rubber surround for extended bass
  • Rugged injection-molded frame
  • High-energy, long-throw neodymium motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE46P-4 provides exceptional range with surprising bass, plus features you’d expect from a much larger driver. Its high-quality design features a paper cone, generous rubber surround, textile spider, high-performance neodymium motor, and an injection-molded frame with gasket for conventional front or rear mounting. It’s perfect for multimedia applications, product displays, miniature speakers, and line arrays.
  • Nominal Diameter2"
  • Power Handling (RMS)3 Watts
  • Power Handling (max)6 Watts
  • Impedance4 ohms
  • Frequency Response150 to 18,000 Hz
  • Sensitivity82.7 dB 2.83V/1m
  • Voice Coil Diameter0.67"
  • Resonant Frequency (Fs)150 Hz
  • DC Resistance (Re)3.49 ohms
  • Voice Coil Inductance (Le)0.14 mH
  • Mechanical Q (Qms)4.91
  • Electromagnetic Q (Qes)1.12
  • Total Q (Qts)0.91
  • Compliance Equivalent Volume (Vas)0.0038 ft.³
  • Mechanical Compliance of Suspension (Cms)1.1 mm/N
  • BL Product (BL)1.73 Tm
  • Diaphragm Mass Inc. Airload (Mms)1.06g
  • Maximum Linear Excursion (Xmax)1.3 mm
  • Surface Area of Cone (Sd)8.35 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.81"
  • Baffle Cutout Diameter1.67"
  • Depth0.88"
  • BrandDayton Audio
  • ModelCE46P-4
  • Part Number285-109
  • UPC848791000454
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (4 Reviews)
  • Weight0.1 lbs.
View similar products to the Dayton Audio CE Series CE46P-4 1-7/8" Paper Full Range Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
