SALE
285-117_ALT_0
Dayton Audio CE Series CE40P-8 1-1/2" Mini Speaker
Brand:|Model: CE40P-8|Part # 285-117
Dayton Audio’s CE40P-8 is an economical small full-range driver that features a high-output neodymium motor, a lightweight paper cone, a front gasket, and a steel frame with two mounting lobes. 8 ohm impedance.
List Price$5.99
Regular Price$4.97
You Save25%
Sale Price
$3.75
Sale Ends6/30/2016
Part # 285-117
  • Paper cone with mylar dust cap for extended highs
  • Rugged stamped steel frame
  • High-energy double neodymium magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE40P-8 provides features you’d expect from a much larger driver, in a size that’s perfect for miniature applications that require wide dispersion and rich, natural sound. Its high-quality design features a paper cone with mylar dust cap, rubber surround, textile spider, high-performance neodymium motor, and a steel frame with dual mounting lobes for conventional mounting.
  • Nominal Diameter1-1/2"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance8 ohms
  • Frequency Response200 to 20,000 Hz
  • Sensitivity83 dB 2.83V/1m
  • Voice Coil Diameter0.51"
  • Resonant Frequency (Fs)227 Hz
  • DC Resistance (Re)7.3 ohms
  • Voice Coil Inductance (Le)0.25 mH
  • Mechanical Q (Qms)4.19
  • Electromagnetic Q (Qes)1.63
  • Total Q (Qts)1.17
  • Mechanical Compliance of Suspension (Cms)0.225 mm/N
  • BL Product (BL)1.56 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.6g
  • Maximum Linear Excursion (Xmax)1.2 mm
  • Surface Area of Cone (Sd)6.76 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.57"
  • Baffle Cutout Diameter1.41"
  • Depth0.9"
  • # Mounting Holes4
  • BrandDayton Audio
  • ModelCE40P-8
  • Part Number285-117
  • UPC848791000379
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (3 Reviews)
  • Weight0.071 lbs.
View similar products to the Dayton Audio CE Series CE40P-8 1-1/2" Mini Speaker
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
