285-101_ALT_0
Dayton Audio CE Series CE32A-8 1-1/4" Mini Speaker 8 Ohm
Brand:|Model: CE32A-8|Part # 285-101
Great-looking and great-sounding, the CE32A-8 miniature speaker driver from Dayton Audio has the goods in a surprisingly small package. Its high-quality design has big-speaker features like an elegant black-anodized aluminum cone, rubber surround, and a neodymium motor. 8 ohm impedance.
List Price$4.99
You Save27%
$3.65
Buy 100+$3.48
Part # 285-101
  • Elegant black-anodized aluminum diaphragm
  • Rubber surround and textile spider for low distortion
  • High-energy double neodymium magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The CE32A-8 provides features you’d expect from a much larger driver, in a size that’s perfect for miniature applications that require wide dispersion and rich, natural sound. Its high-quality design features an elegant black-anodized concave aluminum diaphragm, rubber surround, textile spider, high-output neodymium motor, and a square injection-molded frame drilled for conventional mounting.
  • Nominal Diameter1"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance8 ohms
  • Frequency Response240 to 20,000 Hz
  • Sensitivity77.9 dB 2.83V/1m
  • Voice Coil Diameter0.5"
  • Resonant Frequency (Fs)274 Hz
  • DC Resistance (Re)7.18 ohms
  • Voice Coil Inductance (Le)0.29 mH
  • Mechanical Q (Qms)2.84
  • Electromagnetic Q (Qes)1.25
  • Total Q (Qts)0.87
  • Mechanical Compliance of Suspension (Cms)0.69 mm/N
  • BL Product (BL)2.2 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.52g
  • Maximum Linear Excursion (Xmax)0.7 mm
  • Surface Area of Cone (Sd)3.92 cm²
  • Cone MaterialAluminum
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.26"
  • Baffle Cutout Diameter1.24"
  • Depth0.57"
  • # Mounting Holes4
  • BrandDayton Audio
  • ModelCE32A-8
  • Part Number285-101
  • UPC848791000416
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.065 lbs.
Videos
