285-113_ALT_0
Dayton Audio CE Series CE30P-4 1-1/4" Mini Speaker
Brand:|Model: CE30P-4|Part # 285-113
The Dayton Audio CE30P-4 features a paper cone, round plastic frame, rubber surround, and powerful neodymium motor structure, for small devices and projects that require big sound from a small driver. 4-ohm impedance.
List Price$4.99
You Save15%
$4.25
Buy 100+$3.58
Part # 285-113
  • Extremely compact size in a press-fit frame
  • Paper cone, rubber surround
  • High-output double neodymium magnet motor
Dayton Audio is pleased to introduce the new Commercial Engineering (CE) Series of small loudspeaker drivers. Engineers, designers, and integrators will benefit from how effortlessly these speaker components satisfy the diverse demands associated with consumer electronics and audio-enabled projects.
Multiple types and styles are available within the CE Series driver family. Each was produced to provide excellent audio quality no matter what the overall system design goals may be, and to suit a wide spectrum of engineering requirements. These versatile yet economical loudspeakers are available in sizes from 28 mm (1-1/8") to 90 mm (3-1/2") in diameter, and with power ratings from 1.5 watts to 5 watts continuous RMS power.
The Dayton Audio CE30P-4 provides big-speaker features in an extremely compact unit. It features a paper cone, rubber roll surround, and high-energy double neodymium motor structure, mounted to a robust injection-molded plastic frame that’s perfect for press-fit or glued mounting. Its design makes it perfect for use in multimedia loudspeakers, small docking speakers for portable music players, or compact television frames and sound bars, plus a variety of other applications.
  • Nominal Diameter1"
  • Power Handling (RMS)2 Watts
  • Power Handling (max)4 Watts
  • Impedance4 ohms
  • Frequency Response280 to 14,000 Hz
  • Sensitivity81 dB 2.83V/1m
  • Voice Coil Diameter0.51"
  • Resonant Frequency (Fs)336 Hz
  • DC Resistance (Re)3.4 ohms
  • Voice Coil Inductance (Le)0.19 mH
  • Mechanical Q (Qms)3.62
  • Electromagnetic Q (Qes)1.03
  • Total Q (Qts)0.8
  • Mechanical Compliance of Suspension (Cms)0.34 mm/N
  • BL Product (BL)2.16 Tm
  • Diaphragm Mass Inc. Airload (Mms)0.65g
  • Maximum Linear Excursion (Xmax)0.3 mm
  • Surface Area of Cone (Sd)4.1 cm²
  • Cone MaterialPaper
  • Surround MaterialRubber
  • Magnet MaterialNeodymium
  • Overall Outside Diameter1.25"
  • Baffle Cutout Diameter1.19"
  • Depth0.57"
  • BrandDayton Audio
  • ModelCE30P-4
  • Part Number285-113
  • UPC848791000355
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (1 Reviews)
  • Weight0.05 lbs.
View similar products to the Dayton Audio CE Series CE30P-4 1-1/4" Mini Speaker
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
Videos
