240-610_ALT_0
240-610_ALT_1
240-610_ALT_2
240-610_ALT_3
Dayton Audio BCT-1 Bone Conducting Transducer Exciter 22 x 14mm
Brand:|Model: BCT-1|Part # 240-610
Dayton Audio BCT Transducers produce sound through direct vibration of the bones in the head or are capable of converting surfaces into speakers via vibration when placed on materials such as desks, walls, doors, and many other materials.
Comparable Items In Stock:
Part # 240-610
  • Creates sound using bone conduction
  • Leaves ears free for increased listener safety
  • Can be used as a mini tactile transducer when attached to substrates
  • Wide 300 to 19,000 Hz frequency response
  • 8 ohm impedance with 1W power handling
Unlike conventional transducers that use moving air to produce sound around you, Dayton Audio BCTs (bone conducting transducers) convert the electrical signal into mechanical vibrations so clean, that the brain interprets the vibrating stimulus as excellent sound. Listener's ears are left free to remain aware of their surroundings, increasing personal safety.
When used against materials such as cardboard, wood, steel, and plastics, the BCT operates much like a surface exciter, capable of moving mass to produce robust sound output; much like an invisible speaker! BCTs are excellent for unique OEM sound applications and for the experimenter, where conventional speakers and exciters cannot be used due to size constraints.
Note: The frequency response is given when used as a bone conducting transducer. This will change when attached to a substrate, and different substrate materials will have different frequency responses. Polarity is indicated by a small half-moon above the positive solder point.
Specifications: • Power handling: 1 watt RMS/2 watt max • Le: 1.26 mH • Impedance: 8 ohm • Re: 5.8 ohms • Frequency response: 300-19,000 Hz • Magnet weight: 49 oz. • Fs: 1,600 Hz • SPL: 90.1 dB 1W/1m • Xmax: 5.5 mm • Dimensions (L x W x H): 0.85" x 0.57" x 0.31".
  • Impedance8 ohms
  • Power Handling (RMS)1 Watts
  • BrandDayton Audio
  • ModelBCT-1
  • Part Number240-610
  • UPC848791000065
  • Product CategoryExciters & Tactile Transducers
  • Weight0.02 lbs.
View similar products to the Dayton Audio BCT-1 Bone Conducting Transducer Exciter 22 x 14mm
in the Exciters & Tactile Transducers product category.
