Dayton Audio 2.7k/3.8k Hz 2-Way Crossover Board
Brand:|Part # 269-117
Save up to 50% off the original retail price on this unique, high-quality Dayton Audio crossover board through this Parts Express clearance sale. 2,700 Hz (8 ohm setting) and 3,800 Hz (4 ohm setting) crossover points.
  • Three 250V polypropylene capacitors
  • One 18 AWG air core inductor and an 18 AWG multi-tap iron core inductor
  • 4Ω and 8Ω woofer settings for use with many different speakers
  • In 4Ω setting, one inductor tap is used and two caps are in parallel for a higher value
  • In 8Ω setting, two equal value inductor taps are placed in series for double the single tap value
Due to a manufacturer's error on our recent shipment, this popular Dayton Audio crossover was received with component values that shift the crossover point. This unique crossover is designed to work with four or eight ohm speakers and features high quality Dayton Audio polypropylene capacitors, an air core inductor for the tweeter, and a multi-tap, iron-core inductor for the woofer.
Save up to 50% the regular retail price through this Parts Express exclusive clearance sale.
Features and Specifications:
• Crossover points*: 3,800 Hz @ 4 ohm woofer setting, 2,700 Hz @ 8 ohm woofer setting
• Three 2.7 uF capacitors
• Inductors: Woofer: 0.35 mH using the 4 ohm woofer setting, 1.41 mH using the 8 ohm woofer setting, Tweeter: 0.72 mH
• Four mounting holes are built into the crossover board
• 300 watt power handling
• Dimensions: 6-1/2" W x 4-1/4" H x 1-3/8" D
• 0.205" terminals
*Crossover point based upon static impedance values. When used with speakers, the actual value may shift up or down. To be used as a general guideline.
  • Crossover Type2-Way
  • ConfigurationAssembled Board Only
  • BrandFactory Buyouts
  • Part Number269-117
  • UPC848791001383
  • Product CategoryAssembled Passive Crossovers
    (1 Reviews)
  • Weight1.0000 lbs.
