Dayton Audio 18" Reference Series HO Subwoofer and Cabinet Bundle
Brand:|Part # 300-7094
Build the ultimate in high fidelity bass reproduction using this superior subwoofer cabinet and the Dayton Audio RSS460HO-4 Reference Series 18" High Output subwoofer. Save over $40 off original retail price when you purchase this knock-down enclosure and subwoofer package.
List Price$524.99
You Save27%
$384.88
Part # 300-7094
  • 4.0 cubic foot CNC-cut cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • Includes the ultimate in low distortion bass: Dayton Audio's 18" Reference Series High Output sub
  • Save over $40 off standard retail when you purchase this bundle
Buy this 4.0 cubic foot knock-down cabinet together with the Dayton Audio RSS490HO-4 18" subwoofer (at regular price) and save over $40 off the regulat retail price!
About the Cabinet
This particular cabinet is designed specifically for the Dayton Audio 18" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 18-3/16" or less, and a cutout requirement of 16-3/4" or less. The sealed enclosure design creates a subwoofer system with a Qtc of 0.644 and an f3 of 40 Hz when used with the Dayton Audio RSS460HO-4 and minimal fill. Adding five pounds of Acousta-Stuf will create a critically damped subwoofer system.
During the CNC manufacturing process, rabbets dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 18" High Output Reference Series subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle and bracing): 4.0 cubic feet • External dimensions: 23" H x 20" W x 20.75" D • Subwoofer recess: 1/2" • Weight: 62 lbs. • Made in the U.S.A.
About the Subwoofer
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure.
A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
Specifications: • Power handling: 900 watts RMS/1,800 watts max • VCdia: 3" • Le: 2.24 • Impedance: 4 ohms • Re: 3.2 ohms • Frequency range: 20-500 Hz • Fs: 18.8 Hz • Sensitivity: 93 dB 2.83V/1m • Vas: 9.61 cu. ft. • Qms: 4.05 • Qes: 0.35 • Qts: 0.32bull; Xmax: 12.75 mm • Dimensions: Overall diameter: 18.17", Cutout diameter: 16.69", Depth: 8.94".
Dayton Audio 18" Reference Series HO Subwoofer and Cabinet Bundle includes the following items:
Qty Part # Item
1295-472Dayton Audio RSS460HO-4 18" Reference HO Subwoofer 4 ohm
1300-7079Denovo Audio Knock-Down MDF 4.0 cu. ft. Subwoofer Cabinet for Dayton Audio 18" Reference Series HO or Ultimax Subwoofer
  • Cabinet OptionsUnfinished/Unassembled
  • Speaker TypeSubwoofer
  • Woofer Diameter18"
  • Input Rating4 ohm
  • ConfigurationSubwoofer
  • ColorUnfinished
  • Cabinet Dimensions (H x W x D)23" x 20" x 20.75"
  • BrandParts Express
  • Part Number300-7094
  • UPC848791000799
  • Product CategorySpeaker Kits
    (9 Reviews)
  • Weight105.35 lbs.
View similar products to the Dayton Audio 18" Reference Series HO Subwoofer and Cabinet Bundle
in the Speaker Kits product category.
