Dayton Audio 15" DVC Subwoofer and Cabinet Package
To get the most performance out of a subwoofer, you need a great cabinet. This knock-down cabinet is specifically designed for Dayton Audio's DVC385-88 to extract the best performance possible. Save 50% off the original price of the cabinet when you purchase it together with the DVC385-88 subwoofer.
  • 3.0 cubic foot CNC-cut cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • Includes the versatile Dayton Audio DVC385-88 15" DVC subwoofer
  • Save 50% off the original price on the cabinet when purchased with the sub at regular price
300-7098
Weight: 71.4 lbs.
IN STOCK
List Price$259.99
You Save23%
$199.88
Part # 300-7098
Buy this 3.0 cubic foot knock-down cabinet together with the Dayton Audio DVC385-88 15" subwoofer (at regular price) and save half off the original price of the cabinet. That's a savings of over $60!
About the Cabinet
This particular cabinet is designed specifically for the Dayton Audio DVC385-88 15" DVC subwoofer, but works for any subwoofer with an overall diameter of 15-1/4" or less, and a cutout requirement of 14" or less. You can dial in performance from a Qtc of 0.632 with minimal fill for an f3 of 41 Hz, or add three pounds of Acousta-Stuf for a critically damped Qtc of 0.583 with an f3 of 44 Hz.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 15" DVC subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 3.0 cubic feet • External dimensions: 19.25" H x 19.25" W x 20" D • Subwoofer recess: 7/16" • Weight: 52 lbs. • Made in the U.S.A.
About the Subwoofer
These DVC subwoofers are the most versatile drivers in the Dayton Audio line up. They were engineered to provide very good performance in sealed, vented, bandpass or even transmission line designs. The dual 8 ohm voice coils allow for use in a variety of applications and wiring configurations.
Each driver features a heavy gauge stamped steel frame, super stiff Kevlar impregnated paper cone, thick foam surround, flat progressive spider, vented pole piece, dual high power Kapton voice coils, heavy duty braided tinsel leads, and rubber magnet cover. Made in the U.S.A.
Specifications: (Note: All specifications are with voice coils connected in parallel) • Power handling: 350 watts RMS/700 watts • VCdia: 2" • Le: 1.82 mH • Impedance: 4 ohm • Re: 2.8 ohms • Frequency range: 20-450 Hz • Magnet weight: 112 oz. • Fs: 19 Hz • SPL: 90 dB 1W/1m • Vas: 8.2 cu. ft. • Qms: 8.66 • Qes: 0.38 • Qts: 0.36 • Xmax: 15.1 mm • Dimensions: Overall diameter: 15.16", Cutout diameter: 13.76", Depth: 6.57".
Dayton Audio 15" DVC Subwoofer and Cabinet Package includes the following items:
Qty Part # Item
1300-7083Knock-Down MDF 3.0 cu. ft. Subwoofer Cabinet for Dayton Audio DVC385-88 15" DVC Subwoofer
1295-190Dayton Audio DVC385-88 15" DVC Series Subwoofer
  • Cabinet OptionsUnfinished/Unassembled
  • Speaker TypeSubwoofer
  • Woofer Diameter15"
  • Input Rating8 ohm
  • ConfigurationSubwoofer
  • ColorUnfinished
  • Cabinet Dimensions (H x W x D)19.25" x 19.25" x 20"
  • BrandParts Express
  • Part Number300-7098
  • UPC848791000836
  • Product CategorySpeaker Kits
    (1 Reviews)
  • Weight71.4 lbs.
View similar products to the Dayton Audio 15" DVC Subwoofer and Cabinet Package
in the Speaker Kits product category.
Dayton Audio 15" DVC Subwoofer and Cabinet Package is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Easy to build and sounds greatI found the box easy to build and finish and the speaker to sound really good. It doesn't go as loud as my other sub   http://billfitzmaurice.net/THT.html   but it'll shake things on a different floor of the house without too much trouble and it was about a zillion times easier to build.
Date published: 2013-11-25
  • 2015-01-29T18:22CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_300-7098, PRD, sort_mostRecent
What plate amplifiers would you recommend for this kit?  I would like to tackle this project in stages.  I would like first to buy a plate amplifier to experiment with an old BSR 15" (DAK) passive subwoofer with cabinet, which is in good shape.
Asked by: Richard34
A good amplifier for this setup would be our Dayton SPA250 which you can see below.http://www.parts-express.com/dayton-audio-spa250-250-watt-subwoofer-plate-amplifier--300-803
Date published: 2014-09-23
modify cabinet for plate amp
How can I modify the 3.0cf knock-down cabinetto fit my Dayton Audio SPA250 Plate Amp?(required amp opening is 8-1/2" x 8-1/2")Would like answer asap for making the Father's Day SaleThanks!
Asked by: sgib
You will have to cut the opening in the rear panel of the cabinet for the amplifier.
Date published: 2013-09-02
Customer projects that include: Dayton Audio 15" DVC Subwoofer and Cabinet Package
