Dayton Audio 12" Reference Series HO Subwoofer and Cabinet P
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Package
This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for use with the Dayton Audio RSS315HO-4 and a plate amplifier with bass boost. Save 50% off the original cabinet price when you purchase it with the Dayton Audio RSS315HO-4 in this package.
  • 1.5 cubic foot CNC-cut cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • Includes the ultra-low distortion Dayton Audio 12" Reference Series High Output subwoofer
  • Save 50% off the original price on the cabinet when purchased with the sub at regular price
300-7092
Weight: 59 lbs.
IN STOCK
List Price$249.99
You Save21%
$196.67
Part # 300-7092
Buy this 1.5 cubic foot knock-down cabinet together with the Dayton Audio RSS315HO-4 12" subwoofer (at regular price) and save half off the original price of the cabinet. That's a savings of over $45!
About the Cabinet
This particular cabinet is designed specifically for the Dayton Audio RSS315HO-4 12" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 12-3/8" or less, and a cutout requirement of 11-1/8" or less. For optimum performance, the cabinet is oversized to allow for the use of a plate amplifier with bass boost (such as the Dayton Audio SPA250 or Dayton Audio SPA500 plate amplifiers) to extend the frequency response while staying musical.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 12" Reference Series High Output subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and subwoofer volume): 1.25 cubic feet • External dimensions: 15.5" H x 15.5" W x 16.25" D • Subwoofer recess: 1/2" • Weight: 37 lbs. • Made in the U.S.A.
About the Subwoofer
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure.
A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high output version for automotive applications or for equalized high-power home subwoofers.
Specifications: • Power handling: 700 watts RMS/1400 watts max • VCdia: 2-1/2" • Le: 1.93 mH • Impedance: 4 ohms • Re: 3.4 ohms • Frequency range: 26-600 Hz • Fs: 31.6 Hz • Magnet weight: 150 oz. • SPL: 85 dB 1W/1m • Vas: 1.18 cu. ft. • Qms: 4.27 • Qes: 0.45 • Qts: 0.41 • Xmax: 12.3 mm • Dimensions: Overall diameter: 12.36", Cutout diameter: 11.10", Depth: 5.75".
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Package includes the following items:
Qty Part # Item
1300-7077Knock-Down MDF 1.5 cu. ft. Subwoofer Cabinet for Dayton Audio 12" Reference Series HO Subwoofer
1295-466Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm
  • Cabinet OptionsUnfinished/Unassembled
  • Speaker TypeSubwoofer
  • Woofer Diameter12"
  • Input Rating4 ohm
  • ConfigurationSubwoofer
  • ColorUnfinished
  • Cabinet Dimensions (H x W x D)15.5" x 15.5" x 16.25"
  • BrandParts Express
  • Part Number300-7092
  • UPC848791000775
  • Product CategorySpeaker Kits
    (2 Reviews)
  • Weight59 lbs.
View similar products to the Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Package
in the Speaker Kits product category.
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Package is rated 4.5 out of 5 by 2.
Rated 5 out of 5 by from Very well made and easy to Assemble.Put 2 of these in my Son's Tahoe and the neighbors are not happy!The speakers are absolute beasts with a 150 oz magnet these had to be placed in very well made cabinet and the Dayton enclosure is perfect.
Date published: 2014-12-15
Rated 4 out of 5 by from Nice EnclosureAfter purchasing this kit i thought it was a good value for the money. The enclosure went togethere with ease and all the pieces fit nicely. I was impressed by the quality of the Dayton Audio driver, but was not very impressed by the performance of this unit. I thought maybe it was a power issue so i switch to a proaudio 950watt amp briged mono@4ohm and still just didnt produce much low-end. Iwas trying to step up from my powered JBL 10" sub, but this unit did not perform as well as the JBL.
Date published: 2013-08-13
  • 2015-03-26T06:36CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_300-7092, PRD, sort_mostRecent
Do you recommend filling the enclosure with Acousta-Stuf Polyfill Speaker Cabinet Damping Material? If you do, how much and what would the effect be with doing so?
Asked by: vosub
We generally recommend about a half pound per cubic foot of volume. Adding stuffing to a sub will have minimal audible changes but it will lower the enclosure Q slightly.
Date published: 2015-02-25
Would this be better than getting two dayton sub 1200s?  I'm looking for accuracy. What amp should impair with this?
Asked by: Ty___
Two subwoofers are always going to be better than one, regardless of model. Two 1200's will have more output capability and provide a smoother room response due to more placement options. Having said that, two of the reference kits would outperform two of the 1200's quite easily, but there is a vast difference in cost. We recommend the SPA500 for the 12" reference kit.
Date published: 2014-06-25
What is the F3/F10 of this design? What amp settings should be used and how does this impact the F3/F10?
Asked by: mtmpenn
Modeled F3/F10 is 61 Hz and 29 Hz. Amp settings will be determined by room response. Most rooms have a 10-20 dB peak somewhere between 40 and 60 Hz and the PEQ is designed to bring that peak down to even the overall response in the room.
Date published: 2013-10-17
Adding a round port
If I added a round port to this box what would you recommend for the diameter and length?
Asked by: Brandon
A port in this kit is not recommended. The diameter and length would be too large to fit in the enclosure in order to achieve a decent tuning frequency.
Date published: 2014-01-17
  • 2015-03-26T06:31CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_300-7092, PRD, sort_recentQuestionsFirst
Customer projects that include: Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Package
