BUNDLE
300-7092_ALT_0
300-7092_ALT_1
300-7092_ALT_2
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Bundle
Brand:|Part # 300-7092
This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for use with the Dayton Audio RSS315HO-4 and a plate amplifier with bass boost. Save over $25 off the original retail price when you purchase this bundle.
List Price$363.98
You Save40%
$218.88
Part # 300-7092
  • 1.5 cubic foot CNC-cut cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • Includes the ultra-low distortion Dayton Audio 12" Reference Series High Output subwoofer
  • Save over $25 off the original retail price when you purchase this bundle
Buy this 1.5 cubic foot knock-down cabinet together with the Dayton Audio RSS315HO-4 12" subwoofer (at regular price) and save over $25 off the original price!
About the Cabinet
This particular cabinet is designed specifically for the Dayton Audio RSS315HO-4 12" Reference Series High Output subwoofer, but works for any subwoofer with an overall diameter of 12-3/8" or less, and a cutout requirement of 11-1/8" or less. For optimum performance, the cabinet is oversized to allow for the use of a plate amplifier with bass boost (such as the Dayton Audio SPA250 or Dayton Audio SPA500 plate amplifiers) to extend the frequency response while staying musical.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with recesses to perfectly install the first piece of the two-part, double thick baffle.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 12" Reference Series High Output subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and subwoofer volume): 1.25 cubic feet • External dimensions: 15.5" H x 15.5" W x 16.25" D • Subwoofer recess: 1/2" • Weight: 37 lbs. • Made in the U.S.A.
About the Subwoofer
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intermodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure.
A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high output version for automotive applications or for equalized high-power home subwoofers.
Specifications: • Power handling: 700 watts RMS/1400 watts max • VCdia: 2-1/2" • Le: 1.93 mH • Impedance: 4 ohms • Re: 3.4 ohms • Frequency range: 26-600 Hz • Fs: 31.6 Hz • Magnet weight: 150 oz. • SPL: 85 dB 1W/1m • Vas: 1.18 cu. ft. • Qms: 4.27 • Qes: 0.45 • Qts: 0.41 • Xmax: 12.3 mm • Dimensions: Overall diameter: 12.36", Cutout diameter: 11.10", Depth: 5.75".
Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Bundle includes the following items:
Qty Part # Item
1300-7077Denovo Audio Knock-Down MDF 1.5 cu. ft. Subwoofer Cabinet for Dayton Audio 12" Reference Series HO Subwoofer
1295-466Dayton Audio RSS315HO-4 12" Reference HO Subwoofer 4 Ohm
  • Cabinet OptionsUnfinished/Unassembled
  • Speaker TypeSubwoofer
  • Woofer Diameter12"
  • Input Rating4 ohm
  • ConfigurationSubwoofer
  • ColorUnfinished
  • Cabinet Dimensions (H x W x D)15.5" x 15.5" x 16.25"
  • BrandParts Express
  • Part Number300-7092
  • UPC848791000775
  • Product CategorySpeaker Kits
    (2 Reviews)
  • Weight59 lbs.
View similar products to the Dayton Audio 12" Reference Series HO Subwoofer and Cabinet Bundle
in the Speaker Kits product category.
