Dayton Audio 10" Ultimax Subwoofer and Cabinet Package
This superior subwoofer cabinet is CNC-machined for precise panels and is specifically built for use with the Dayton Audio Ultimax 10" subwoofer. Save 50% off the original cabinet price when you purchase it with the 10" Ultimax subwoofer in this package.
  • 1.25 cubic foot CNC-cut cabinet made of 3/4" MDF panels with a 1-1/2" thick front baffle
  • Includes Dayton Audio's no-holds-barred 10" Ultimax subwoofer
  • Save over $40 off the original price of the cabinet when purchased with sub at regular price
300-7095
Weight: 51.35 lbs.
IN STOCK
List Price$249.99
You Save20%
$199.68
Part # 300-7095
Buy this 1.25 cubic foot knock-down cabinet together with the Dayton Audio UM10-22 10" Ultimax subwoofer (at regular price) and save half off the original price of the cabinet. That's a savings of over $40!
About the Cabinet
This particular cabinet is designed specifically for the Dayton Audio 10" Ultimax subwoofer, but works for any subwoofer with an overall diameter of 10-3/4" or less, and a cutout requirement of 9-9/16" or less. When used together with minimal fill, the box and subwoofer combine to create a critically damped subwoofer with a Qtc of 0.589 and an f3 of 45 Hz.
During the CNC manufacturing process, rabbets and dadoes are cut into the back panel for precise panel alignment. A unique two-piece brace adds superior rigidity without affecting the subwoofer's performance. Both side panels feature 3/4" rabbeted extensions with rabbeted recesses to perfectly install the first piece of the two-part, double thick baffle. Plate amplifier installation is made easy by following the scribed interior guide with a jig saw and by modifying one of the braces.
The end result is a resonance-free, sealed subwoofer cabinet that is purpose-built to extract the best performance from Dayton Audio's 10" Ultimax subwoofer. All that's left to do is finish it to match your décor or paint it to stand out. When your friends ask about it, you get the pleasure of saying, "I built it myself!"
Specifications: • Panel thickness: 3/4", front baffle is 1-1/2" • Panel material: Medium Density Fiberboard (MDF) • Finished net cabinet volume (subtracting the double thick baffle, bracing, and woofer volume): 1.25 cubic feet • External dimensions: 15.25" H x 15.25" W x 15.25" D • Subwoofer recess: 1/2" • Weight: 35 lbs. • Made in the U.S.A.
About the Subwoofer
The Ultimax Series of dual voice coil subwoofers, from Dayton Audio, are not for the faint of heart. Built using the latest in subwoofer technology, Ultimax subwoofers are the pinnacle of low frequency driver design. An Ultimax subwoofer tests the strength of your foundation with fast, articulate, gut-wrenching bass.
Over 1-1/2" of travel (3/4" Xmax) is kept completely linear through the use of dual spiders that also limit distortion and rocking modes. "Tall-boy" rubber surrounds with integrated gaskets maintain driver surface area during extreme excursion moments. Thick, one-piece Nomex honeycomb covered cones are covered with woven, heavy-duty glass fibers creating ultra-still cones that resist deformation.
Specifications: • Power handling: 500 watts RMS/1,000 watts max • Le: 1.27 mH • Impedance: 4 ohms  (2 ohms/coil) • Re: 3.3 ohms • Frequency range: 25-1,500 Hz • Fs: 26.2 Hz • SPL: 86.4 dB 2.83V/1m • Vas 1.24 cu. ft. • Qms: 3.03 • Qes: 0.54 • Qts: 0.46 • Xmax: 19 mm • Dimensions: Overall diameter: 10.77", Cutout: 9.32", Mounting depth: 5.7".
Note: All parameters derived with voice coils wired in series.
Dayton Audio 10" Ultimax Subwoofer and Cabinet Package includes the following items:
Qty Part # Item
1300-7080Denovo Audio Knock-Down MDF 1.25 cu. ft. Subwoofer Cabinet for Dayton Audio 10" Ultimax Subwoofer
1295-510Dayton Audio UM10-22 10" Ultimax DVC Subwoofer 2 ohms Per Coil
  • Cabinet OptionsUnfinished/Unassembled
  • Speaker TypeSubwoofer
  • Woofer Diameter10"
  • Input Rating2 ohm
  • ConfigurationSubwoofer
  • ColorUnfinished
  • Cabinet Dimensions (H x W x D)15.25" x 15.25" x 15.25"
  • BrandParts Express
  • Part Number300-7095
  • UPC848791000805
  • Product CategorySpeaker Kits
    (1 Reviews)
  • Weight51.35 lbs.
View similar products to the Dayton Audio 10" Ultimax Subwoofer and Cabinet Package
in the Speaker Kits product category.
Dayton Audio 10" Ultimax Subwoofer and Cabinet Package is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Warm, Deep Bass!I received this last night via: UPS and came appropriately packaged. The sub is beefy and stout. Put the box together and some people state there not being direction but its pretty straight forward. Lined the box with acoustic foam and put 1lb. of  filling; the bass is deep and everything rattles in m house. I own a reference 10 and the difference between the two I would say is the reference is of course clean but the ultimax is a brute, powerful and stout!
Date published: 2014-01-15
I was looking for a nice sub for my car and found this kit. Will I be able to use this in my car?
Asked by: ShawnCzerw
Yes this would work fine in an automotive application.
Date published: 2014-02-12
How does the speaker go into this thing?
I just purchased this package, and I'm having trouble putting it together. Probably a silly question, but the speaker is supposed to go into the front baffle cutout so that the rim of the speaker sits in the recess, right? Because if so, then the recess isn't near large enough - off by a 1/4 of an inch in diameter. So I guess, followup question: how would you recommend I resize the recess?
Asked by: pieinthesky1
Now this is interesting. These cabinets usually fit together. If you have not already glued the back braces to the box, you can remove them and use a powered or unpowered jig saw to remove a small circle in them. If it's glued--you can still do that with the same method, but it will be harder to do. Another way, is to put a round shim that's 1/4" in the recess. Felt or rubber could be used without affecting the sound as long as its air tight.
Answered by: Joe from San Francisco
What about a plate amplifier?
Is there room on the back of this cabinet to install a plate amplifier? From the pictures it looks as if the bracing would be in the way.Thanks
Asked by: jtheisen521
There is room for a plate amplifier on the rear of the enclosure. The 300-807 is a great choice for the Ultimax 10".
Customer projects that include: Dayton Audio 10" Ultimax Subwoofer and Cabinet Package
