DataComm 45-0041-WH Recessed Low Voltage Media Plate with Duplex Surge Suppressor White
Brand:|Model: 45-0041-WH|Part # 261-514
DataComm Electronics' new, patented Recessed Low Voltage Media Plates offer the convenience of a duplex surge receptacle and a recessed plate with enough room to store the low voltage cables behind your flat panel TV.
$59.92
Buy 10-19 $54.93
Buy 20+$50.71
Part # 261-514
  • 15 Amp/125 Volt duplex surge receptacle with replaceable Surge Bloc ®
  • Mounting wings are molded into the media plate and fasten tightly against the back of the drywall
  • Conceal multiple AV cables behind your flat panel TV
  • Quick and easy to install. No additional parts needed
DataComm's low voltage media plate with surge receptacle includes an outlet box with 15 A/125V replaceable duplex Surge Bloc. This bulk cable power plate is perfect for storing cables behind your flat panel TV while powering the TV too!
Specifications: • Maximum surge current - 12,000 amps • Peak suppression voltage - 1,000 volts • Hot/Neutral,  Hot/Ground, Neutral/Ground • Total maximum surge dissipation - 340 joules
PRODUCT SPECIFICATIONS
  • SizeIrregular
  • ConnectorsAC Outlet
  • FinishWhite
  • BrandDataComm Electronics
  • Model45-0041-WH
  • Part Number261-514
  • UPC660559008423
  • Product CategoryBulk Cable Wall Plates
  • Weight1.25 lbs.
View similar products to the DataComm 45-0041-WH Recessed Low Voltage Media Plate with Duplex Surge Suppressor White
in the Bulk Cable Wall Plates product category.
I'm thinking about buying a Datacomm 45-0041-WH Recessed Low Voltage Media Plate w/Duplex Surge Suppressor. My question is: "How does the surge suppressor trip & reset?" Is it resettable, or do you have to replace a fuse, etc?
Asked by: GillC
This receptacle requires a replacement surge block if it is ever tripped. This is Datacomm part number 45-0041-SB.
Date published: 2014-02-12
  • 2016-02-07T07:29CST
  • loc_en_US, sid_261-514, PRD, sort_recentQuestionsFirst
