DataComm 45-0017-LA Split Plate with Flexible Opening - Lite Almond
Brand:|Model: 45-0017-LA|Part # 261-547
The DataComm split plate with flexible opening enables audio/video wires and cables to pass through the wall behind your TV, amplifier, or other devices. Two interlocking halves combine to make a single bulk cable wall plate.
List Price$5.56
You Save47%
$2.92
Buy 10+$2.68
Part # 261-547
  • An easy retrofit: the plate splits into two wire-encircling sections
  • Run up to six A/V cables through your wall
  • Both plate halves create a virtually seamless design
  • Quick and easy to install
  • Perfect for eliminating connections at the wall
  • Low profile design easily fits behind flat screen TVs
  • Fits standard single-gang low voltage mounting ring
Create a discrete in-wall pass-through for your audio/video cables with the DataComm split plate. Available in white, black, ivory, and lite almond; split plates install in just a few minutes. The bulk wire split plate is installed around existing low voltage cables, eliminating the need to re-pull wires. The low profile design fits behind even the thinnest flat screen televisions and mounts. This DataComm split plate accepts up to six low voltage cables, providing a clean appearance to your home theater setup.
PRODUCT SPECIFICATIONS
  • SizeSingle Gang
  • FinishAlmond
  • BrandDataComm Electronics
  • Model45-0017-LA
  • Part Number261-547
  • UPC660559011805
  • Product CategoryBulk Cable Wall Plates
  • Weight0.0730 lbs.
View similar products to the DataComm 45-0017-LA Split Plate with Flexible Opening - Lite Almond
in the Bulk Cable Wall Plates product category.
