180-998_ALT_0
180-998_ALT_1
180-998_ALT_2
DAC Digital to Analog Audio Converter Optical / Coaxial / USB
Brand:|Part # 180-998
Enjoy your high-definition audio tracks played through your stereo audio system or headphones.
List Price$89.99
You Save27%
$65.90
Buy 4+$62.97
Part # 180-998
  • Supports up to 24 bit, 192 kHz audio files
  • USB, S/PDIF coaxial and S/PDIF toslink audio inputs
  • Built-in headphone amplifier
  • Stereo line audio output via RCA jacks
  • USB or externally powered
This Digital to Analog Audio Converter accepts all PCM digital audio and converts to stereo analog audio. With all of the inputs the serious user will need; USB, toslink and coaxial digital audio, this unit will connect to virtually any audio source. The USB input allows you to connect directly to a PC. The Coaxial and toslink connections allow you to convert digital audio outputs from AV devices to stereo audio; DTS and Dolby Digital turned off.
Specifications: • Input: S/PDIF optical/coaxial 44.1 - 192 kHz • Sample rate: 44.1, 48, 88.2, 96, 176.4 or 192 kHz • Input: USB 1.1 compatible with 2.0 • Sample rate: 44.1, 48 or 96 kHz • Output: Stereo line level via 2 RCA jacks • Output impedance: 10K ohm • Output voltage: 1.35 Vrms • Headphone: 3.5 mm stereo jack • Headphone output power: 60 mW into 16 ohms, 30 mW into 32 ohms • Power: 5 VDC, 500 mA • Dimensions: 4.4" L x 4.1" W x 1.2" H
Note: The digital input signal format for this convertor is PCM. The ability to use this device with a television to convert the digital audio output to analog audio is specific to the television. Check your television user manual to see if the SPDIF output can be changed from Dolby Digital to PCM.
  • BrandParts Express
  • Part Number180-998
  • UPC844632086267
  • Product CategoryDigital Audio/Video Converters
    (24 Reviews)
  • Weight0.75 lbs.
View similar products to the DAC Digital to Analog Audio Converter Optical / Coaxial / USB
in the Digital Audio/Video Converters product category.
Videos
