Bonus Item Incl.
245-405_ALT_0
Crown XTi 1002 XTi 2 Series Power Amplifier
Brand:| Model: XTi 1002
The all-new XTi 2 Series amps by Crown continue to set the standard for unmatched performance and value, delivering the goods night after night without breaking a sweat. Crown's 1002 XTi 2 Series power amplifier has up to 1,400 watts power.
  • Peakx Plus™ Limiters provide the ultimate in system performance and protection by allowing full control over threshold, attack, and release
  • Enhanced Subharmonic Synth section provides user control over frequency, gain and filter type for system-specific tuning
  • 3 User-defined fan mode controls – normal, early and fullspeed – for matching fan performance to a specific application
  • New system monitoring provides software visibility of AC line voltage and power supply temperature
  • Integrated cast-aluminum handles for easy handling and enhanced durability
  • Locking power cord clip provides a secure connection between the amplifier and power cord
  • Updated HiQnet Band Manager™ and System Architect™ control software
245-405
Weight: 21.5 lbs.
IN STOCK
List Price$998.00
You Save50%
$499.00
Crown Baseball Cap
Qty: 1Part # 520-304
List Price:$19.99
Part # 245-405
The all-new XTi 2 Series amps by Crown continue to set the standard for unmatched performance and value, delivering the goods night after night without breaking a sweat. There's no debate – when you choose Crown’s XTi 2 Series, you’re choosing one of the most powerful and innovative amplifiers on the market today. Crown's 1002 XTi 2 Series power amplifier has up to 1,400 watts power.
With such innovations as a universal tracking switch-mode power supply and a fully integrated suite of speaker processing tools, these amps are at the top of their class when it comes to thermal efficiency and system flexibility. You also have greatly improved control capabilities. The addition of Peakx Plus™ Limiters gives you full command over threshold, attack and release, and we enhanced the Subharmonic Synth so you can easily manage frequency, gain and filter type, allowing for application-specific tuning.
Plus, you'll now be able to tailor fan speed for specific applications and have software visibility of the power supply temperature and AC line voltage. Combine all of that with integrated cast-aluminum rack handles for maximum durability and portability and you have the power to move you – and the world.
Integrated Processing
Input EQ:
6 parametric filters per channel with adjustable Q, ±15 dB boost/cut. Also adjustable high and low shelving filters. This 8-filter EQ section can be bypassed
Crossover filters: Highpass and Lowpass per channel. Butterworth 6/12/18/24 dB per octave. Linkwitz-Riley 24/48 dB per Octave. Also includes ± 15 dB bandpass gain and polarity control
Output EQ: 8 parametric filters per channel with adjustable Q, ±15 dB boost/cut. This 8-filter EQ section can be bypassed
Delay: For signal alignment of driver; 50 mS of total delay
SubHarmonic synth: Takes the low-frequency content of the input signal and "synthesizes" a new signal that is the same as the input signal but one octave lower. The new synthesized signal is then mixed with the original signal to create the effect. Users have control over frequency, gain, and filter type
Peakx™ plus limiter: User defeatable limiter that allows users to control Threshold, Attack, and Release times
Presets: 30 total presets, 29 of which are user-definable
Controls
Level:
Two front-panel rotary level controls, one for each channel
Power switch: On/Off switch applies AC power to the amplifier
Sel/Prev/Next Buttons: Three buttons near the LCD screen that are used to access menu items and front panel lockout
LCD Screen: Backlit liquid crystal display that shows preset and processing status
Input/Output Connectors
Input connectors:
XLR, one per channel
Link/Out connector: Loop-thru signal from input connector for linking another amplifier, one per channel
Output connectors: Two Neutrik® Speakon® NL4MP output connectors, Channel-1 Speakon® is wired with Ch. 1 and Ch. 2 outputs for use with optional single 4-conductor cable, Two binding post outputs (in parallel with Speakon® connectors)
HiQnet™ USB connector: Type B, connects to HiQnet™ network
Construction
Chassis:
Steel
Front panel: Cast-aluminum
Cooling: Proportional speed fan with front-to-rear airflow
Specifications: • Output power (stereo, per channel, @ 1 kHz, 20 ms burst, both channels driven): 275 watts @ 8 ohms, 500 watts @ 4 ohms, 700 watts @ 2 ohms • Output power (bridge-mono mode, @ 1 kHz, 20 ms burst): 1,000 watts @ 8 ohms, 1,400 watts @ 4 ohms • Sensitivity (for full rated power at 4 ohms): 1.4V RMS • Frequency response (at 1 watt, +0 dB, -1 dB): 20 - 20,000 Hz • S/N Ratio (below rated 1 kHz power at 8 ohms): 100 dB (A weighted) • THD: <0.5% • Damping factor (20 Hz to 1 kHz):> 500 • Crosstalk (below rated power): 20 - 1,000 Hz: >70 dB • Input impedance (nominal): 20k ohms balanced, 10k ohms unbalanced • Maximum input signal: +22 dBu typical • AC Line voltage and frequency configurations: 120 VAC 60 Hz • AC Line current (120 VAC amplifier playing 1/8 power pink noise into 4 ohms per ch): 6.8A; no more than 38 watts at idle • Operating temperature: 0°C to 40°C at 95% relative humidity (non-condensing) • Dimensions: 19" W x 3.5" H x 12.25" D • Net weight: 18.5 lbs. (8.4 kg).
  • Power Output (RMS Per Channel @ 8 ohms)275 Watts
  • Output Channels2
  • Weight Range20 to 29 lbs.
  • BrandCrown Audio
  • ModelXTi 1002
  • Part Number245-405
  • UPC871015005232
  • Product CategoryAmplifiers - Live Sound
    (3 Reviews)
  • Weight21.5 lbs.
View similar products to the Crown XTi 1002 XTi 2 Series Power Amplifier
in the Amplifiers - Live Sound product category.
Crown XTi 1002 XTi 2 Series Power Amplifier is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from Complete overkill.....I own 2 of these amps and 2 pair Cerwin Vega 12" 3-way VS Series. Left channel 1,400 watts 4 ohms bridge-mono as with right channel 1,400 watts 4 ohms bridge-mono each amp running 1 pair.... I love the quality very clean power but I need to buy bigger speakers to match them properly is my only complaint lol
Date published: 2013-04-15
Rated 5 out of 5 by from The Crown of CrownsOver the years I have used amps like Adcom, Ashley, and Crown. CROWN amps have never ever shut down, get to hot. CROWN amps sound is alive. The best of the best ..........
Date published: 2013-12-25
Rated 4 out of 5 by from Home Theatre ApplicationI use this power amplifier to drive 2 Cerwin Vega 380SE Cabinets (vintage audio). Its a great amplifier, quiet cooling fan, clean sound and good cosmetics. The only complaints i have is the banana jacks - you need to attached from the top. But mostly disappointed in the Sub Harmonizer - you can only use it in sub woofer mode. I wanted to add some low end to my classic recordings in full range mode, it wont allow this. I hope they fix this in the next firmware update.
Can the x-over point be customized? The owers manual shows, "off, 90, 100Hz...and then custom". I would like a x-over point of 115 Hz.
Asked by: Ken L
The amp can be connected to a computer via USB (on the back panel). Then you download from the crown website the "band manager" program. This will allow you to access all the parameters. From there you can input whatever crossover point you want, select the type of crossover, the rolloff, add eq, delay, limiting, and sub-harmonic synth.
Answered by: Matt
Subsonic
Can you set a subsonic filter with this amp?
Asked by: Cleveland
Each channel allows a high pass and low pass filter to be set so it can be used as a subsonic filter.
Answered by: Chrisf
How low can the highpass filter (to use as a lowcut/subsonic filter) be set?
Can the highpass filter on each channel be set to 20 Hz, or only to 50 Hz as on some of the other Crown amp models (e.g., XLS 2000)?
Asked by: Skip2
The DSP is fully customizable. You can input any frequency you desire.
Answered by: Matt
Customer projects that include: Crown XTi 1002 XTi 2 Series Power Amplifier
