Bonus Item Incl.
245-500_ALT_0
245-500_ALT_1
Crown XLS 1000 DriveCore Series Power Amplifier
Brand:| Model: XLS 1000
Tired of lifting heavy amp racks? Switch to Crown XLS Series DriveCore™ amplifiers and save money while saving your back! Class D efficiency, integrated PureBand™ crossovers, and onboard Peakx™ peak limiting are included.
  • XLS High Performance, Lightweight Class D amp weighs less than 11 lbs.
  • Integrated PureBand™ Crossover System for better performance and control
  • Peakx™ Limiters provide maximum output while protecting your speakers
  • Efficient forced-air fans prevent excessive thermal buildup
  • Electronically balanced XLR inputs; touchproof binding post and Speakon® outputs
  • Precision detented level controls, power switch, and power LED
  • Six LEDs indicate signal, clip & fault for each channel
245-500
Weight: 11.05 lbs.
IN STOCK
List Price$499.00
You Save40%
$299.00
Crown Baseball Cap
Qty: 1Part # 520-304
List Price:$19.99
Part # 245-500
Crown's XLS Series amplifiers define the standard for portable PA systems with unmatched performance, technology and affordability. Its advantageous flexibility includes XLR, 1/4", RCA inputs so you can plug in anything and play anywhere, along with several system setup configurations.
The XLS1000 amp's integrated crossovers and switch-mode power supply produce superior sound, and Peakx™ limiters protect your speakers. Weighing less than 11 pounds, compared to 40 pounds for its competitors, it's much easier to set up and move from show to show. Simply put, the XLS is most reliable, versatile, efficient amp available today. Three-Year, No-Fault, Fully Transferable Warranty.
Specifications: • Power output, stereo mode (EIA 1 kHz, both channels driven): 215 watts x 2 (8 ohms), 350 watts x 2 (4 ohms), 550 watts x 2 (2 ohms) • Output power, bridged mono mode (EIA 1 kHz): 700 watts x 1 (8 ohms), 1,100 watts x 1 (4 ohms) • Distortion (typical): <0.5% @ 8 and 4 ohms, <1% @ 2 ohms • Frequency response (@ 1 watt, 20 Hz - 20 kHz): +0 dB, -1 dB • S/N ratio: >97 dB (A-weighted) • Crosstalk: @ 1 kHz >85 dB; @ 20 kHz >55 dB • Input sensitivity (@ 4 ohms): 1.4V • Input impedance: 20k ohms balanced, 10k ohms unbalanced • Load impedance: Stereo 2 ohms minimum per channel; 4 ohms minimum in bridge mono • Damping factor (8 ohms, 10 Hz - 400 Hz): >200 • Dimensions: 3.5" (2RU) H x 19" W x 7.7" D • Weight: 8.6 lbs.
XLS Series with Integrated DriveCore™ Technology
The XLS Series of power amplifiers from Crown define the standard for live sound systems with unmatched performance, technology, and affordability. This high-performance line consists of four models each providing enormous power and flexibility thanks to the integrated DriveCore™ Technology, PureBand™ Crossover System and Peakx™ limiters. And weighing in at only 11 lbs. or less, they provide the ultimate in lightweight portability.
Class D amplifiers are notable for extraordinarily high efficiency and being well suited for driving difficult reactive loads such as subwoofers. However, their performance can suffer impaired performance on marginal and unstable AC line supplies.
To overcome this obstacle, Crown engineers developed DriveCore™ Technology – a proprietary hybrid analog-digital integrated circuit (IC) developed with Texas Instruments that drives the "front end" of the Class D output stage. Over 60 years of Crown's design knowledge and experience went into the development of this technology resulting in truly remarkable benefits.
DriveCore™ Technology provides an extremely wide-tolerance with regards to sagging or "dirty" AC line conditions providing consistent performance without affecting audio quality. This means that your performance will not be compromised by fluctuating generator power or overloading by lighting rigs, backline gear, etc.
In addition, DriveCore™ Technology's patented feedback and PWM modulation circuits enable fast recovery on peak transients, accurate reproduction of low-level detail, and precise tracking of low-frequencies at high power levels for maximum subwoofer output.
Advanced Switched-Mode Power Supply
This advanced power supply is highly efficient and optimized for maximum power transfer from the AC line through the Class D output stage to the loudspeakers. A benefit to this is substantial weight reduction when compared to older 60 Hz transformer-based power supplies. All four models in the line weigh 11 pounds or less with no compromise in performance. This makes the XLS Series the benchmark for high performance lightweight portability.
The PureBand™ Crossover System in the XLS Series adds an enormous amount of flexibility and performance to any system. With this system, the crossover frequency is completely variable allowing the choice of any crossover point between 50 Hz and 3 kHz on 1/12 octave centers. The use of 4th order Linkwitz-Riley filters provides steep slopes for a seamless transition between high and low drivers. All of the PureBand™ Crossover System settings can be fully configured quickly and easily from the front panel using the intuitive LCD interface.
  • Power Output (RMS Per Channel @ 8 ohms)215 Watts
  • Weight Range10 to 19 lbs.
  • BrandCrown Audio
  • ModelXLS 1000
  • Part Number245-500
  • UPC871015003740
  • Product CategoryAmplifiers - Live Sound
    (19 Reviews)
  • Weight11.05 lbs.
View similar products to the Crown XLS 1000 DriveCore Series Power Amplifier
in the Amplifiers - Live Sound product category.
Crown XLS 1000 DriveCore Series Power Amplifier is rated 4.7895 out of 5 by 19.
Rated 5 out of 5 by from It's almost freeI bought this amp because first it has plenty of power at leastfor my needs and secondly it's ability to drive low impedanceloads down to 2 ohm. I'm using it in my stereo system for thebass, on the left side I have a pair of 18 inch woofers in openbaffle and on the right side a pair of 15 inch woofers also inopen baffle crossed over at 157 and a pair of 3 inch Tang Band full range drivers , I might later add some f-mods tofilter out the bass from the full rangers. This amp is anincredible bargain . If it just had a stereo high pass it would be the perfect amp. Okay I know what your thinking , why18 inchers on one side and 15 inchers on the other side, because that's what I had on hand and on the right side ofmy room I needed more space to walk through. It doesn'tsound unbalanced because of L&R output level feature.
Date published: 2013-09-21
Rated 5 out of 5 by from Crown XLS 1000I bought this amp to clean up my keyboard sounds. It works great, the keys sound great. The additional feature of an active crossover will be useful in the future when I add more low end to the system.
Date published: 2013-08-27
Rated 2 out of 5 by from Not the right application.Low output.Amplifier has good build quality. Easy to set up and the X-overwas solid. Before I bought this amp I read a lot of reviewsit looked like it would work for a home theater sub, some people had good luck with it. This amp needs 1.4v minimuminput low level. It really likes 2v or more to perform rightbeing a pro audio piece it make sense. My receiver at high volume and the sub gain all the way up maxed out at 1v. So if you are using this amp the way I did check your output voltage on your receiver.
Date published: 2013-07-08
Rated 5 out of 5 by from Very pleased so farI haven't used this amp much, but enough to know it performs great so far. If the reliability is there long term, it's going to be one of the best gear purchases I've made.I played a two night outdoor gig in late June 2013 in upper 90 degree temp. I used the amp to drive two bass cabinets on one channel and one cabinet on the other. I was in "Y" input mode and had the amp in crossover mode with ch 1 lows below 250Hz to a single EV 15" 8 ohm cab and an Ampeg HLF 410 4 ohm cab (2.67 ohm load on ch 1). Channel 2 highs were into a Peavey 4 ohm 410 cab.It was ridiculously loud and clear on both low and high end. I ended up removing the EV 15 from the low side because it was drowning the guitarist in sub-low freq. The cooling fan hardly ran at all. You could feel no heat coming off the amp. I ended up calling Crown (Harman) to ask about the fan. It's working, it just doesn't have to much and it's super quiet. The amp is also nearly dead quiet with just a very light hiss out of the tweeters I was driving.I have tried bridge mono mode into an old Peavey cabinet with two EV 400 watt cast frame 15". It's insanely loud and clear. I don't think the cabinet would take the 1100 watt output, and I don't think I got it close to that level.The amp will be used mostly as a monitor system amp in the future. It hasn't served in that roll yet, but if it performs as well as it did with electric bass, we should be able to hear ourselves....
Date published: 2013-07-01
Rated 5 out of 5 by from The only way to great sounding speakersFinally, an amp with an adjustable crossover in it. or at least the first one I've come across, multiple xover points 12dB linkwitzriley perfect solution to power robbing passive networksI highly recommend this line of amps and could not be happierwith the product. Hows it sound ? as the old adage once saidtry it you'll like it.
Date published: 2013-06-27
Rated 5 out of 5 by from Great amp!Lots of power and very clear sound. Bought this to replace an aging Sherwood 6040 I've had since the early 80s. Well, this is definately a big improvement. Barely gets warm even at extremely high output levels and really drives the bass. I use this amp to drive multiple speakers in the house and also 4ea 6x9 car speakers in my house boat when we go out on the lake. Easily drives the 6x9s on the boat to maximum output (1.75 ohms in parallel config). Just clean/clear sound output. Speakers can really put out a thump on this amp. Very impressed and satisfied with this amp.
Date published: 2013-06-08
Is this amplifier also available in 220VAC for the european Market ?
Asked by: KDLke
Unfortunately no, the only model we offer is 120VAC.
Date published: 2014-08-25
Will this amp power 6 pairs of 8 ohm speakers in a restaurant with each pair running through an impedence matching volume control ?
Asked by: bigeye67
Yes this amp will work well for an application like that.
Date published: 2014-08-15
Will the 1/4" stereo headphone jack on my home receiver work as an input source for this amp using a 1/4" to stereo RCA adaptor for channels 1 & 2 ?
Asked by: bigeye67
This will work but you will need to be very careful of your gain structuring.
Are the wattage ratings at 2 ohm (550w per channel) RMS or Peak? Regarding the crossover, some amps will send LP to one channel, while sending HP to the other channel. I want to make sure both channels can be set to LP so I can drive two subs? Thanks!
Asked by: AoSJake
Yes the power ratings are RMS. This amp will allow both channels to be low passed.
Date published: 2014-07-21
Would this be good for cerwin vega E-312  rated at 300 watts?
Asked by: Luislopez98
Yes this amplifier will work well with those speakers.
Date published: 2014-06-09
Can this amplifier be used with a Yamaha home theatre receiver using the RCA inputs?
Asked by: sodie323
Yes this can be used with a home audio receiver.
Date published: 2014-05-19
Customer projects that include: Crown XLS 1000 DriveCore Series Power Amplifier
Discussions in our TechTalk Forum that include: Crown XLS 1000 DriveCore Series Power Amplifier
