Cooling Fan 12 VDC 120 x 120 x 38mm 95 CFM
Brand:|Part # 250-064
12 VDC cooling fan 120 x 120 x 38 mm.
List Price$6.99
You Save31%
Buy 4-49 $4.56
Buy 50+$4.25
Part # 250-064
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
  • Low noise
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. These fans come with 3-pin header plug that can be removed for custom applications.
Specifications: • Operating voltage: 12 VDC • Power: 4 watts • Speed: 2500 RPM • Airflow: 95 CFM • Noise: 40 dB • Dimensions(mm): 120 W x 120 H x 38 D.
  • Operating Voltage12 VDC
  • Size120 mm
  • Bearing TypeSleeve Bearing
  • BrandParts Express
  • Part Number250-064
  • UPC848864007380
  • Product CategoryFans & Cooling
  • Weight0.4500 lbs.
View similar products to the Cooling Fan 12 VDC 120 x 120 x 38mm 95 CFM
in the Fans & Cooling product category.
