Cool Components CP-SF Single Fan Cooling Unit
Brand:|Model: CP-SF|Part # 305-200
The CP-SF circulates air away from equipment protecting it from heat and heat related failures. Place the CP-SF on top of equipment or mount it to the back of a cabinet to pull air out and away from components. Perfect for cable and satellite receivers or larger components where heat is an issue.
Part # 305-200
  • Quiet & efficient operation
  • Effectively circulates air around equipment
  • Quick and easy installation
  • Low profile allows placement in tight spaces
  • Uses a variable voltage power supply to adjust fan speed (Cool Components PS-500, sold separately)
  • Necessary for any equipment rack
  • Affordable cooling system
The CP-SF circulates air away from equipment protecting it from heat and heat related failures. Simply place the CP-SF on top of equipment or mount it to the back of a cabinet to pull air out and away from components. It is perfect for cable and satellite receivers or larger components where heat is a concern. The CP-SF is constructed from heavy gauge steel which is extremely durable (ideal for pro sound applications), but it also acts as a large heat sink increasing the efficiency of the unit. A top-quality levitation blower uses a floating gasket to eliminate noise. The unit operates on DC voltage and by adjusting the voltage can be run virtually silent or more aggressively depending on the application. Available in two models: a "Standard" version for normal heat issues and a "High Velocity" model for extreme heat applications. Use the PS-500 power supply # 305-305.
Specifications: • Enclosure: Heavy gauge steel • Fan: Brushless levitation blower • Air flow: 4 CFM max • Noise: ~20 dB max • Power connection: 2.1 mm jack (center pin positive) • Voltage: 7 to 12 VDC • Current: 40 mA max • Power consumption: 0.5W max • Dimensions: 5-1/8" W x 1" H x 4" D.
Note: While these units are designed to be placed on components to circulate air, it is not recommend that you deviate from the manufacturer recommendations for ventilation. This would include blocking component vents or leaving less than the typical 4" above an amplifier or receiver. If it is impossible to follow the manufacturer specifications, then our units are ideal for providing additional ventilation but should not simply be used as a substitute for following manufacturer specifications.
  • Product TypeCooling Systems
  • BrandCool Components
  • ModelCP-SF
  • Part Number305-200
  • UPC844632057601
  • Product CategoryEquipment Cooling
    (4 Reviews)
  • Weight0.7001 lbs.
View similar products to the Cool Components CP-SF Single Fan Cooling Unit
in the Equipment Cooling product category.
Videos
