Cool Components CP-DF Dual Fan Cooling Unit
Brand:|Model: CP-DF|Part # 305-210
The CP-DF set-top, dual fan unit aggressively circulates and moves air away from equipment protecting it from heat. Designed for amplifiers and receivers it is constructed from heavy gauge steel for a great look, but the steel also acts as a large heat sink increasing the efficiency of the unit.
- Order Soon - Only 3 Left In Stock
List Price$115.00
You Save17%
$95.50
Part # 305-210
  • Dual fans
  • Quiet and efficient operation
  • Low profile allows placement in tight spaces
  • Quick and easy installation
  • Uses a variable voltage power supply to adjust fan speed (Cool Components PS-500, sold separately)
  • Necessary for any equipment rack
  • Affordable cooling system
The CP-DF set-top, dual fan unit aggressively circulates and moves air away from equipment protecting it from heat and thermal shutdown. Designed for amplifiers and receivers it is constructed from heavy gauge steel for a great look, but the steel also acts as a large heat sink increasing the efficiency of the unit. Two high-quality levitation blowers (brushless with a special bearing system) are mounted on floating gaskets to eliminate noise. It operates on DC voltage and by adjusting the voltage the unit can be run silent or more aggressively depending on the application. Uses the PS-500 power supply (sold separately).
Specifications: • Enclosure: Heavy gauge steel • Fan: 2 brushless levitation blowers with a special bearing system • Air flow: 8 CFM max • Noise: ~28 dB max • Power connection: 2.1 mm jack (center pin positive) • Voltage: 7 to 12 VDC • Current: 80 mA max • Power consumption: 1W max • Dimensions: 6-1/4" W x 1" H x 4" D.
Note: While the CP-DF series of coolers are designed to be placed on units to circulate air, it is not recommend that you deviate from manufacturer recommendations for ventilation. If it is impossible to follow the manufacturer specifications, then our units are ideal for providing additional ventilation but should not simply be used as a substitute for deviating from manufacturer specifications.
  • Product TypeCooling Systems
  • BrandCool Components
  • ModelCP-DF
  • Part Number305-210
  • UPC721762430132
  • Product CategoryFans & Cooling
    (4 Reviews)
  • Weight0.9001 lbs.
View similar products to the Cool Components CP-DF Dual Fan Cooling Unit
in the Fans & Cooling product category.
Videos
