Cool Components CP-CC-100HV Single Fan Cooling
Brand:|Part # 305-205
The CP-SF-HV (High Velocity fan) circulates air away from equipment protecting it from heat and heat related failures. Place the CP-SF-HV on top of equipment or mount it to the back of a cabinet to pull air out and away from components.
Part # 305-205
  • Quiet & efficient operation
  • Effectively circulates air around equipment
  • Quick and easy installation
  • Low profile allows placement in tight spaces
  • Necessary for any equipment rack
  • Affordable cooling system
  • Uses a variable voltage power supply to adjust fan speed
The CP-SF-HV (High Velocity fan) circulates air away from equipment protecting it from heat and heat related failures. Simply place the CP-SF-HV on top of equipment or mount it to the back of a cabinet to pull air out and away from components. It is perfect for cable and satellite receivers or larger components where heat is a concern. The CP-SF-HV is constructed from heavy gauge steel which is extremely durable (ideal for pro sound applications), but it also acts as a large heat sink increasing the efficiency of the unit. A top-quality levitation blower uses a floating gasket to eliminate noise. The unit operates on DC voltage and by adjusting the voltage can be run virtually silent or more aggressively depending on the application. This louder, High Velocity version of the CP-SF fan is designed for extreme heat applications and is much louder than the standard CP-SF fan. Use the CA-TR-100 power supply # 305-305. Specifications: *Enclosure: Heavy gauge steel *Fan: Brushless levitation blower *Air flow: 4 CFM max *Noise: ~20 dB max *Power connection: 2.1mm jack (center pin positive) *Voltage: 7 to 12 VDC *Current: 40 mA max *Power consumption: .5W max *Dimensions: 5-1/8" W x 1" H x 4" D.
  • BrandCool Components
  • Part Number305-205
  • UPC844632057618
  • Product CategoryEquipment Cooling
  • Weight0.7001 lbs.
View similar products to the Cool Components CP-CC-100HV Single Fan Cooling
in the Equipment Cooling product category.
Videos
