299-521_ALT_0
299-521_ALT_1
299-521_ALT_2
299-521_ALT_3
299-521_ALT_4
299-521_ALT_5
Community CU-CUTTER Adjustable Drywall and Ceiling Tile Hole Saw Cutter for 1-3/16" to 10" Holes
Brand:|Model: HA4568|Part # 299-521
Cut clean 1-3/16" to 10" holes quickly, in most materials, using just your drill with Community's patented CU-CUTTER hole saw, and save over 60% off the manufacturer's suggested price through this Parts Express exclusive buyout!
  • Adjusts to cut clean holes from 1-3/16" to 10" in diameter without a mess
  • Tungsten carbide bit included for cutting metal up to 1 mm thick
  • Includes speed steel bit for materials such as plywood
  • Works with almost any drill
Community's patented CU-CUTTER adjustable hole saw attaches to any drill with a 3/8" chuck (or larger) and cuts 1-3/16" to 10" diameter holes in materials up to 7/8" (23 mm) thick, 1-3/4" thick if cut from both sides, such as: plasterboard, fiberboard, plywood, wood, and acylic sheets using a high speed steel blade. A tungsten carbide cutting blade is included to cut holes in aluminum, brass, and other metal sheets up to 1 mm thick.
The CU-CUTTER includes an impact-resistant, transparent cowl for watching your surface as you cut, while keeping your eyes, face, and your surroundings free from debris. Built onto the cowl is a rubberized support base that steadies the hole saw without marring your working surface. A compression spring absorbs vibrations, while also working with a locknut to adjust cutting depth. Four balance bars are included for stability, and a polyurethane protection tube is included to act as a stop for the center drill bit. Protective carrying case included.
Save over 35% similar hole saws, and 60% off the original retail price through this Parts Express exclusive factory buyout. Hurry, supplies are extremely limited!
  • BrandFactory Buyouts
  • ModelHA4568
  • Part Number299-521
  • UPC848864018133
  • Product CategorySaws, Hole Saws & Ceiling Hole Cutters
    (1 Reviews)
  • Weight7.5500 lbs.
View similar products to the Community CU-CUTTER Adjustable Drywall and Ceiling Tile Hole Saw Cutter for 1-3/16" to 10" Holes
in the Saws, Hole Saws & Ceiling Hole Cutters product category.
