Common Cathode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE11115|Part # 073-012
This package includes 100 common cathode RGB LEDs together with 200 voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
Part # 073-012
  • Rated to last over 10 years
  • Includes 200 voltage dropping resistors (100 for 5 VDC, 100 for 12 VDC)
  • Up to 5,000 mcd of output
RGB LEDs are great for creating custom light effects for displays, in vehicles, on motorcycles, instrument panels... anywhere accent lighting is needed. These RGB LEDs are waterproof for use on boats or outdoors and are tested to last 100,000 hours (over 10 years) and use virtually no power at all—1/4 watt at most—while providing up to 5,000 mcd of output. Also included are resistors to use these common cathode RGB LEDs with 5 or 12 VDC sources.
Use the larger included resistors in series with the 12 VDC power supply positive and the desired color's anode. Use the smaller resistor in series with the 5 VDC power supply positive and the desired color's anode.
• Size: 5 mm
• Lens color: water clear
• Forward current: 20 mA
• Life rating: 100,000 hours
• Forward voltage: Red: 2 to 2.4 VDC, Green: 3.4 to 3.8 VDC, Blue: 3.4 to 3.8 VDC
• Viewing angle: 25° to 35°
• Luminous intensity: 4,000 to 5,000 mcd
  • Size5mm (T-1 3/4)
  • Emitting ColorRGB
  • Lens Type / ColorWater Clear
  • Luminous Intensity4000-5000 mcd
  • Application TypeTri-color
  • BrandParts Express
  • ModelDC-LE11115
  • Part Number073-012
  • UPC844632093401
  • Product CategoryLEDs
  • Weight0.3125 lbs.
View similar products to the Common Cathode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
