Common Cathode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13137|Part # 073-112
This package includes 10 common cathode RGB LEDs together with voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
List Price$7.99
You Save38%
$4.98
Buy 4+$4.70
Part # 073-112
  • Rated to last over 10 years
  • Includes voltage dropping resistors for 5 VDC and 12 VDC source voltage
  • Up to 5,000 mcd of output
RGB LEDs are great for creating custom light effects for displays, in vehicles, on motorcycles, instrument panels... anywhere accent lighting is needed. These RGB LEDs are waterproof for use on boats or outdoors and are tested to last 100,000 hours (over 10 years) and use virtually no power at all—1/4 watt at most—while providing up to 5,000 mcd of output. Also included are resistors to use these common cathode RGB LEDs with 5 or 12 VDC sources.
Use the larger included resistors in series with the 12 VDC power supply positive and the desired color's anode. Use the smaller resistor in series with the 5 VDC power supply positive and the desired color's anode.
• Size: 5 mm
• Lens color: water clear
• Forward current: 20 mA
• Life rating: 100,000 hours
• Forward voltage: Red: 2 to 2.4 VDC, Green: 3.4 to 3.8 VDC, Blue: 3.4 to 3.8 VDC
• Viewing angle: 25° to 35°
• Luminous intensity: 4,000 to 5,000 mcd
  • Size5mm (T-1 3/4)
  • Emitting ColorRGB
  • Lens Type / ColorWater Clear
  • Luminous Intensity4000-5000 mcd
  • Application TypeTri-color
  • BrandSure Electronics
  • ModelDC-LE13137
  • Part Number073-112
  • UPC848864000305
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.01 lbs.
View similar products to the Common Cathode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
Common Cathode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great RGB LED Value, You won't find betterJust tested these little suckers and they work great. I was a bit sceptical with the price (Since buying these from a major supplier would be more than twice the price without the resistors), but they all work, and well.Be aware that these are Common Cathode[CC] (Each LED shares a common grounding point). PE also sells Common Anode[CA] (Part # 073-112) if your project requires that instead. I just mention because a lot of Multiple LED Drivers require CA RGBs.To figure out which pin is which, find the longest pin. That is your common grounding point. The single pin next to it is the Red Anode and the other two are Green then Blue Anodes as you move away from it.Using a 12 VDC Supply:510Ω (Green-Brown-Black-Black-Thin Brown) Red Pin470Ω (Yellow-Purple-Black-Black-Thin Brown) Green & Blue PinsUsing a 5 VDC Supply:180Ω (Brown-Grey-Black-Black-Thin Brown) Red Pin100Ω (Brown-Black-Black-Black-Thin Brown)) Green & Blue PinsIf you are a more visual person, I have included a Pin Out and Wiring Diagram.NOTE: I notice that someone that bought the Common Anode LEDs had the green and blue pins reversed. Be sure to check your own LEDs before designing permanent parts to your circuit.
Date published: 2013-08-03
  • 2016-02-14T07:19CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-112, PRD, sort_mostRecent
